Master Brake Cylinder Replacement: Questions! - Defender Source
Old April 7th, 2011, 11:48 AM
NC Rover
Nick
1971 Series IIa Hybrid
I was hoping someone could identify the Master Brake Cylinder pictured and show me where I could buy another one? I believe it is an early 110 Master Cylinder. I currently have disc brakes on the front and drum brakes in the back. Brake pressure is equalized through a small equalizer...that is leaking as well (see below).
Question #1: Any idea which Master Brake Cylinder this is?
Question#2: Is this a difficult thing to replace or is it as easy as swapping out like the Master Clutch Cylinder?
Question #3: If there is a small leak running down right below where the Master connects to the "black disc" (no idea what the name of that part is), shoudl I replace just the master cylinder or both the cylinder and the big black thing that I dont' know the name of?
https://lh5.googleusercontent.com/_Kbx2YtP9U1Y/TZ3ch2ZMuEI/AAAAAAAAAqY/mQX_zD9Fhzs/Master%20Brake%20Cylinder.png
1971 Series IIa Hybrid: 2.5L MILSPEC 5-Main Bearing Engine|Turner Engineering Performance Head w/ oversized hardened steel valves & phase shift/increased lift cam|LT77 Tranny/LT230 Transfer Case|11mm Ignition Wires/Super Coil|Jacobs Ignition/Petronix Ignitor|D90 Axles|Galvy Frame|Old Man Emu Coils|Cust Rear/Side Fuel Tanks|Cust Drive Shafts|
Old April 7th, 2011, 11:58 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
http://www.rovahfarm.com/seriesbrakespage1.htm
You could also try a rebuild kit as the front seal is leaking. The"black disc" is the booster and should be fine.
Old April 7th, 2011, 12:20 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
The brake master cylinder is a 110 one.. The black disk you're talking about is the brake booster or servo. You can rebuild the master cylinder if the bore are alright. Otherwise it will leak. In my opinion change the thing as it's not expensive. For the brake booster, if it work, don't touch it.
ac, brake, master
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Brake Master Cylinder Leak chris snell Defender Technical Discussions 12 September 28th, 2011 09:50 AM
Brake Master Cylinder Rebuild HELP Heath Defender Technical Discussions 2 August 7th, 2006 05:11 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
