Mass air flow meter - Defender Source
Old April 9th, 2014, 09:00 AM
hotroddef90's Avatar
hotroddef90
Rod Renfrow
1995 Defender 90 ST
Mass air flow meter
Seems like my mass air flow meter is cuasing my check engine light to go on.
Anyone know where I can get a good replacement air flow meter?
Old April 9th, 2014, 09:06 AM
have you tested it? They are expensive to replace ... especially if there isn't anything particularly wrong with it.
Old April 9th, 2014, 09:17 AM
hotroddef90
Rod Renfrow
1995 Defender 90 ST
How do u test it?
Old April 9th, 2014, 09:37 AM
The reason the MAF sensor throws a code is basically the engine gets a measurement it knows can't be true .... the reasons for this are numerous ... but start with connections ... are they all clean and free of corrosion.
next clean it with MAF cleaner ... carefully ... just buy it and spray it on liberally
The MAF measures air flow so make sure the air getting to the engine is the same as the air measured ... check ALL the hoses for air leaks ... the plenum hose is a classic for rotting out ... see the big fat plenum hose thread ...
once you've assured that the hoses are good ( including checking underneath them ) you need to use something like rover gauge to see what is happening when it throws a code.
I'm looking for a doc that has the manual check procedure and will post a link when i find it.
Old April 9th, 2014, 09:42 AM
hotroddef90
Rod Renfrow
1995 Defender 90 ST
Can it be repaired?
Or do u have to replace?
Old April 9th, 2014, 09:47 AM
I don't think they are serviceable ... but also think it's unlikely there is anything wrong with it if the truck runs OK.
Air Mass Meter for RRC Baja 90 Wanted 4 April 3rd, 2013 07:16 PM
Range Rover Classic 3AM Mass Air Flow Meter Wolf Fabrication For Sale - Parts 0 August 15th, 2012 08:13 PM
3.9 Mass Air flow sensor rgrrvr Wanted 2 June 13th, 2007 11:46 PM
Code 12 - MAF Mass air flow Antonios Defender Technical Discussions 3 August 6th, 2006 06:58 PM
Mass air flow sensor! TwisteD90 Wanted 1 October 20th, 2005 06:50 PM
