Marker lights illuminating when applying brake - Defender Source
Old July 28th, 2016, 07:10 PM
Toddtippin
Todd tippin
1994 defender 90
1994 D90
Its been in storage a while(years) and being recommissioned. I have at least one issue with the elec and possibly two.
Symptom1 :
Side marker lights and possibly the front marker lights illuminate when brakes are applied while the headlights are not on. New bulbs have been recently installed. Failed switch? Corrosion? Wrong bulbs?
Symptom 2:
The battery will drain overnight if left connected. New battery has been installed. The radio is aftermarket and about 10 years old.
Recent work performed by a professional:
Fuel Pump, Brake master cylinder.
Thanks advance.
Todd
Old July 28th, 2016, 07:33 PM
The light issue is most likely a bad ground for the lights in the rear. The brake lights ground out through the common connection to the marker lights.
The battery drain, you need to trace down with a meter.
Old July 28th, 2016, 10:26 PM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
Ha!!....I'm sorting through a "front brake light" as well, right now. Turn signal goes off when I hit the brakes but the front turn indicator comes on like a brake light. Looks like it is a ground issue in the rear.
Old July 29th, 2016, 01:21 AM
Nooner's Avatar
Nooner
Ryan Noonan
1994 D90 NAS #159
Recently had multiple bad-ground problems myself. Ended up running 5 dedicated grounding wires: one behind dash and one to each corner of my 90. Used 8 gauge tinned marine wire.
Possible overkill? Most likely.
Any more grounding problems? No
Added benefit of making it way easier to tune my CB antenna.
brake, ht, lights
Side Marker Lights 1of40 Wanted 3 August 10th, 2009 11:49 AM
Left brake lights work....the right and door brake lights won't? beko35 Defender Technical Discussions 4 June 27th, 2009 01:12 PM
headlight, marker, signal lights 97Ariesblu Wanted 3 June 14th, 2007 02:53 PM
Wanted Front side marker lights for a 95 D-90 Departing90 Wanted 0 March 18th, 2007 04:39 PM
LED Marker Lights? chris snell Defender Technical Discussions 16 April 17th, 2006 12:50 PM
