Marine Stereo Install Advice - Defender Source
Old January 9th, 2012, 03:27 PM
Hinckley423's Avatar
Hinckley423
Charles Joerss
1995 D-90 #2812
I'm planning to replace my stereo and speakers for my 95 D-90. I want to use marine speakers and a marine stereo. I looked through past forms and I think that I found some good speakers but I'm unsure if they'll fit. I'm unsure how to choose one that will fit properly and that will involve no wiring changes or modifications. I know very little about this stuff and any help with choosing a new stereo would be appreciated. I know that there are a lot of stereo forums on the site but I didn't find any that really answered my question. I apologize in advance if this has already been answered in another post.
Old January 9th, 2012, 03:43 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
Are your speakers in the door or under the dash? I believe all NAS D90 speakers are 6 1/2 in round. So you need something compatible with that. There are speakers up to 6 3/4 and down to 5in-ish that will fit in that hole. If yours has the rubber ring that attaches to the door card under the speaker... that should offer plenty of depth. Same for the rear.
You might need to splice the existing wiring harness for the speakers if the connectors don't fit... they are the spade clip on thingys. But try first before cutting anything.
As for the stereo, I was recom'd to use this harness one by one of the site members: Crutchfield/Metra 70-9400. But I ended up going with a seperate amp so didn't need it. The wiring codes are here: http://www.the12volt.com/installbay/...tail/1252.html if you the harness doesn't work.
Good luck!
marine, sound system, speakers, stereo
Stereo Install Questions jefferson Defender Technical Discussions 14 November 3rd, 2013 02:01 PM
stereo advice Abrooks Defender Technical Discussions 27 August 20th, 2012 10:24 PM
Beautiful 1994 D90 - Stereo Install Ideas! CDN90 Misc. Chit-Chat 15 June 8th, 2010 06:28 PM
Shock Install Advice Grover Defender Technical Discussions 11 September 9th, 2006 09:42 PM
Stereo Install In Dash caschumann Defender Technical Discussions 18 November 4th, 2004 12:41 AM
