Manually turning speedo - Defender Source
Old February 11th, 2005, 07:57 PM
artm
Arthur Maravelis
97 SW
Just replaced my KPH one with MPH with less miles than mine. Can I simply turn the numbers or do I have to connect a cable? If I need a cable how about disconnecting it and attaching to a drill to turn it? I only have about 20K miles to go!
Old February 11th, 2005, 08:12 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
If you take the glass off carfully, you can turn the numbers up with your finger. Not down though..
Legend in My Own Mind.
Old February 11th, 2005, 08:33 PM
artm
Arthur Maravelis
97 SW
Thanks Randy. I assume I can turn any of the numbers?
Old February 11th, 2005, 09:45 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Yeah that would really suck if you had to turn only the tenths number for 20,000 miles ...
must ...... keep ......... turning......... gasp
Old February 12th, 2005, 11:15 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yes, It was harder to remove the glass then actually do that. I did the same thing and had to add some 15K to mine so it would match after replacing the speedo with one I bought....
Old February 12th, 2005, 11:46 AM
artm
Arthur Maravelis
97 SW
Jeez! How the heck do I remove the front?! Pry the bezel and all from the rear of the bezel?
There's two screws on the backside but I imagine they hold the guts to the back.
Old February 12th, 2005, 12:45 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yes, pry the small lip on the rear of the bezel. And yes, the screws just hold it into the rear of the case. I dont think you even have to remove them.
Note, by no means am I describing how to alter your original mileage. That is Illegal. This would just be to set the mileage on your new speedo to match your actual vehicle mileage of your old broken speedo...
Old February 12th, 2005, 01:23 PM
artm
Arthur Maravelis
97 SW
I discovered that using a square end driver attached to a drill is by far easier. The only reason for me to remove the front is to replace the lens as it has a scratch on it - not mentioned by the seller!
So, what did you use to pry it off? It's pretty tight there.
Or, perhaps I should into removing the scratch...
Old February 12th, 2005, 01:29 PM
I pried mine off with a small screw driver, if you are careful you can make it look good when you smash it back on.
manual, speedo
VDO SPeedo roverboy Defender Technical Discussions 69 March 1st, 2015 10:35 AM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
Speedo correction d90Monkey Defender Technical Discussions 2 April 21st, 2004 12:05 PM
