Manual transmission whining - Defender Source
Old June 15th, 2005, 09:26 PM
shawom
mitchell shaw
95 ST #2066
I just purchased a '95' with manual trans., the unit shifts smoothly but it seems to whine a lot and bucks a little when driving in 2nd and 3rd when you let off the acceleator. What is up? Is this common to the D90 or does it sound like a possible problem?
I'm new to the Defender but not to Rovers. I have enjoyed the site so far.
Thanks in advance for any thoughts or suggestions.
Mitchell Shaw
2000 RR HSE
1994 RR Classic ( "Le Brahma" )
95 D90
Old June 15th, 2005, 11:40 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
That's just the stock whirlymajig where it mates to the flux capacitor. Don't worry, there's a warning light that comes on if it needs replacing.
No really, I've noticed (as have a lot of others) slop in the drivetrain. The whining would worry me some, but if you turn up the radio (if the speakers still work) that'll go away.
This thread may help:
http://www.defendersource.com/forum/...lop+drivetrain (Just for you Hippert)
"It's not a Jeep"
Old June 16th, 2005, 09:05 PM
shawom
mitchell shaw
95 ST #2066
Thanks for the link to the thread. Seems like this is a common issue with the 5 speed manual transmission.
Old June 22nd, 2005, 01:50 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Talking Get the whining checked out
Shawom,
Get the whining checked out, I purchased my d-90 about 3 years ago (95 as well), & it had a similar whine / noise, come to find out the T-case needed to be replaced. The whine was defiantly present around 2 or 3 gear during 40 to 50 m-p-h. When you take it in have them check the speed"o" - meters transducer as well, after getting the T-case replace this transducer made the truck stall (bad tooth on gear) & gave a similar whine.
Just trying to help out?
Weldon
Weldon
manual, transmission
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
cost of parts to convert manual to automatic transmission mgrgpg Misc. Chit-Chat 9 September 15th, 2006 09:15 PM
380 manual transmission question thewap Defender Technical Discussions 12 May 22nd, 2006 11:10 AM
Question regarding Manual Transmission on 95 D90 DefenderLvr Defender Technical Discussions 9 April 25th, 2006 02:59 PM
manual transmission needed ember Wanted 0 August 31st, 2004 11:50 PM
