manual transmission issue - Defender Source
Old April 23rd, 2012, 11:25 AM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
Need a transmission shop in MD/VA that is familiar with Defender manual tranny
Old April 23rd, 2012, 11:29 AM
whats the issue?
Old April 23rd, 2012, 01:39 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
If it is the R380 anyone who works on classic Jaguar transmissions should be able to help as that is why they were originally designed.
Old April 23rd, 2012, 09:37 PM
ditskovich's Avatar
ditskovich
dmitry
New Ashcroft transmission is tight to go in to reverse. Clutch and its components all new and were adjusted.
Do not know what to do.
Old April 23rd, 2012, 09:38 PM
ajh
Andrew J. Hutton
On the back of the shift housing is the reverse lamp switch; unscrew it a couple turns and see if it shifts into reverse correctly. If it does, add a washer and re-fit and it should be fine.
Old May 1st, 2012, 08:13 AM
ditskovich's Avatar
ditskovich
dmitry
after all it seems like it is clutch issue. It goes in reverse no problem, when the engine is off, and tight when it is on.
Next question: good LR mechanic in MD/VA area?
Open to suggestions.
Help.
Old May 1st, 2012, 08:33 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Give Pierre a call at 4x4 Land in Chantilly http://www.4x4-land.com/main.asp
I bought my 90 in the area and had him look it over before sealing the deal. Then, had him address any issues he thought necessary and change fluids, etc., before driving her home to NY. Very happy with his assessment of the truck and the attention/honesty he gave to a customer he knew he wouldn't see again.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old May 1st, 2012, 09:21 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Help.
Send carlosz a PM. He is in Arlington.
Old May 1st, 2012, 09:24 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Isn't Carlos working for the man now, not Arlington Motors?
Old May 1st, 2012, 09:29 AM
Carlos is working for the county now....but I'd still reach out to him.
Or Paul Warren at British Car Docs:
http://britishandclassics.com/
Old May 1st, 2012, 10:41 AM
It likely just needs bleeding or adjusting the free play at the master. There must be someone closer to his neck of the woods - Gustavo uses a guy named Andrew (but don't recall any details) and Trevor is still closer than Paul.
Originally Posted by pendy
I'm here for the D's
Old May 23rd, 2012, 09:28 PM
ditskovich's Avatar
ditskovich
dmitry
Car is finally fixed.
4x4 Land in Chantilly did the magic!
Third mechanic, so far, trying to fix transmission, and successfully completing it. Last one told me that a new transmission from Ashcroft was defective and that I need to exchange it. And it actually a clutch and a fly wheel.
Works like a clock now.
First time that I enjoy driving it on a way home.
Old May 23rd, 2012, 10:07 PM
I used that shop once and they are pretty good. When I went there the son did all the talking and the father did all the work. If they weren't in West Bumfuk I would use them more often. As it is I go to Dewey Cheatham Motors on Spruell Drive in Kensington.
Old May 23rd, 2012, 10:12 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Good to hear.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old May 23rd, 2012, 10:26 PM
Interesting...hadn't heard of them but I'll keep them in mind. Website: http://www.4x4-land.com/main.asp
Old May 23rd, 2012, 10:41 PM
down_shift's Avatar
down_shift
Russell
Don't let Charles hear your say that!
Old May 24th, 2012, 07:05 AM
West Bumfuk is far nicer than East Bumfuk though! And clearly we have better mechanics too
I think this is the place a friend of mine uses. If it is, he described them as doing good work at a very reasonable price, and id not seem to want to over sell him on things. He said there were two guys who spent have their year here, and the other half overseas, then switched? Something like that.
Nice to hear your problem got fixed Dmitry. If you can come this far for a mechanic you can make it to HH one month!
Old May 24th, 2012, 09:09 PM
ditskovich's Avatar
ditskovich
dmitry
i have to start doing it regularly!
manual, transmission
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
380 manual transmission question thewap Defender Technical Discussions 12 May 22nd, 2006 11:10 AM
Question regarding Manual Transmission on 95 D90 DefenderLvr Defender Technical Discussions 9 April 25th, 2006 02:59 PM
Manual transmission whining shawom Defender Technical Discussions 3 June 22nd, 2005 01:50 PM
manual transmission needed ember Wanted 0 August 31st, 2004 11:50 PM
