Manual to Auto conversion NAS 110 - Defender Source
Old November 13th, 2013, 10:12 AM
Premoto1
Tyler
1997 D90 SW
I've got an NAS 110 that has already had a manual to Auto conversion performed. The problem I'm having is an uneven idle (RPMs drop, come up, drop, come up). My understanding is that the ECU needs to be told the vehicle has an auto gearbox. Any tips on how this procedure can be performed.
Old November 13th, 2013, 10:27 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Have you tried replacing the stepper motor yet?
Old November 13th, 2013, 10:44 AM
Premoto1
Tyler
1997 D90 SW
Already done. Along with plugs, cap, rotor, coil, set ignition timing, idle speed, replace fuel pressure regulator (fuel pressure bleeding off), and fuel filter. Problem seems less pronounced if idle speed is raised. However, not crazy about just raising idle speed to mask a problem.
Old November 13th, 2013, 11:29 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
There is info on ECR's website about it, I actually just stumbled upon it the other day while looking for something else. Essentially I think you just need to connect it to a computer and tell it that it has an Auto.
Old November 13th, 2013, 11:35 AM
ECR had a post explaining how to fix it if you search. Basically you have to add a wire.
Old November 13th, 2013, 11:50 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Ron may be right, but I think the wire is for adding A/C so the ECU knows when the Compressor kicks on and steps up the idle.
IIRC, the Auto Conversion just entails a computer software change.
Old November 13th, 2013, 12:49 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
14CUX ECUs will work with either an automatic or a standard transmission. On a standard transmission equipped truck, ECU pin 34 (Orange/Black) is permanently grounded through a 480 ohm resistor. The same pin on an automatic is wired to the P/N position switch of the automatic transmission which grounds the wire in park or neutral and has no continuity (open circuit) in gear. Disconnect your ECU connector, Ohm check pin 34 to ground and move the shifter through all the gears. You should have zero (or close) ohms to ground in park & neutral and infinite ohms in gear. If you read 480 ohms in park & neutral, then the ECU is wired to the switch correctly but the resistor is still in place. If that is the case, remove the resistor. It will probably be taped into the harnass. May be easier to run a new wire than split the harnass to find it. If Pin 34 has 480 ohms to ground all the time, it isn't wired to the switch and should be. In that case, remove the resistor and wire the switch. See the attached schematic below. It's for a D1 but works for the Defender as well.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old November 22nd, 2013, 11:23 AM
Premoto1
Tyler
1997 D90 SW
This is just what I needed. Now, my truck knows it's an automatic. Unfortunately, it didn't resolve my rough/surging idle. More testing revealed the throttle position sensor to be faulty. Replaced and idle speed is where it should be and rock steady. Thanks to all that replied.
110, conversion, manual, nas, nas 110
Electrical Issues & the best repair manuals for a 1995 D90 agavelvr Defender Technical Discussions 18 August 23rd, 2011 12:54 PM
WTS: NAS 110 AC/heater box headdamage For Sale - Parts 1 October 24th, 2005 08:43 PM
1993 Defender 110 NAS $39K!! in VA ember For Sale - Vehicles 1 November 22nd, 2004 09:29 AM
WTS: 1997 NAS D90 Workshop Manual artm For Sale - Parts 1 October 14th, 2003 12:20 AM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
