Mantec Vs. Rockware Tire Carrier - Defender Source
Old January 4th, 2013, 09:50 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I'm really on a toss up and can't decide. My rear door (it's an SW)is rattling like crazy and creaking.. it's time to finally get the tire off it. I want to put a carrier but can't decide btw. the two. I was hoping to get some input from everyone on their experiences. I know they are both good products from the other threads I've read but I was hoping to get "what's it like to live with" type feedback. Here are my concerns with both:
Mantec:
-Drilling the body and cross member (I really don't like drilling the car)
-With the removal of the bumper, I need to add. fuel tank skid plate, trailer hitch, bumperettes increasing the cost
- This is a guess but probably accepts a smaller tire
Rockware:
- whoa it's expensive (but makes more sense when you consider that it covers the corners so I don't have to buy bumperettes)
- 2 stage opening process
- (From other threads) Chance of rattling?
- Still need to get a trailer hitch
With rockware.. how have people modified their tailgates to remove the three spokes?
Thanks for any input
Old January 4th, 2013, 09:57 AM
bjf's Avatar
bjf
barry f
94 ST #395
Why do you have to remove your bumper for a Mantec?
Old January 4th, 2013, 10:03 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
You don't? I thought your did. Every single photo I've seen of the thing has the NAS rear bumper removed
Old January 4th, 2013, 10:06 AM
bjf's Avatar
bjf
barry f
94 ST #395
Nope. I put one on. Bumper stayed. They don't share mounts. No interference at all.
Old January 4th, 2013, 10:14 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
7 years with the Mantec without issues. I don't remember a lot of drilling for installation. Just put some greasing nipples on articulations.
- Charles Eames
Old January 4th, 2013, 10:44 AM
No comparison IMO
Old January 4th, 2013, 11:07 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
The rattling that I get is pretty much just from the jerry can holders. Since they have the aluminium covers they produce most of the noise. I've been looking for a good rubber tie down system to use. The covers are neat in the sense that they can be locked, but I generally don't just tool around with the jerry cans. I have a bunch of dynamat all over in the holders to help guard from and rattling and that helped alot, but still cant take it all out without removing those metal can covers.
The bumper comes with 2 plates that sandwich the bumper. At first I thought one was supposed to go on the gas tank bulkhead side, but the bolts weren't long enough. And then it got me thinking about the gap between the bumper and the bulkhead. Well I put that plate in that gap it it stiffened it up alot. The bumper was actually flexing a bit there.
If I also would have kept my ST tire carrier hardware I would have modified the rubber stopper to contact the tire carrier which would really stop any movement. But I sold that, so I need to get a new one or make something.
I like mine, but yea it wasn't cheap.
Old January 4th, 2013, 11:10 AM
Mantec ... you have to drill 2 holes where rivets are located in the capping. The lower portion bolts onto the cross member. Insert the lower bolt nut side up to avoid fowling the rear step.
The door plate covers the 3 holes from the old door mount carrier.
Old January 4th, 2013, 11:19 AM
bjf's Avatar
bjf
barry f
94 ST #395
Keep in mind if your door is cracked inside, even with a Mantec it will rattle. I had mine rewelded. It didn't hold. I ended up fixing it with jb weld and covering it with dynamat. That fixed it.
Old January 4th, 2013, 11:26 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
If you were also going to add bumperettes, would you still go Mantec considering that is integrated with the Rockware? I probably wouldn't get the jerry can holders..
carrier, mantec, tire, tire carrier
Rockware tire carrier TDI Guy Defender Technical Discussions 79 March 14th, 2007 05:25 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Mantec Swing-Away Tire Carrier david_jackson Defender Technical Discussions 16 December 17th, 2004 05:24 PM
Mantec Tire carrier Installation Questions Eric Siepmann Defender Technical Discussions 6 November 21st, 2004 01:42 PM
Cheapest MAntec Tire Carrier Nobrega Defender Technical Discussions 5 June 29th, 2004 03:21 PM
