Mantec Tire carrier Installation Questions - Defender Source
Old November 19th, 2004, 09:58 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
I did a mock assembly of the carrier last night to get my bearings straight.
The directions refer to the grab handle for the lower carrier mount. When I looked at the rear crossmember this morning, they're not there. Are they behind the reflector for a 97 SW? Or do does the rear crossmember need to be drilled? If so, is it easier to install the top, partially assemblt the carrier to get the alignment for the rear?
TIA,
EwS
Old November 19th, 2004, 03:32 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
TIA,
EwS
NAS D90's don't have the "Grab-Handles" so there's one less object to remove or modifiy. However, you will need to drill the rear crossmember. I would begin with the top mount, with the bottom in mind of course, followed by the installtion/prep of the bottom mount just as you stated above. Let me know if you have any more quesitons.
DJ
Follow up: Here are two pictures of my install (beat-ya to it Phil! )
Name:	mantec upper mount.jpg
ID:	1910   Click image for larger version
Name:	mantec entire.jpg
Old November 19th, 2004, 05:56 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Question
(slightly h-jackin) mmmh,I wonder if I can fit a Truck Cab tailgate and keep my Mantec carrier in place...
I found one and I'm considering a "TC Summer Conversion Project".
Fitting the gate brackets and "pins" would mean removing the carrier for correct opening...alternatively,a modified tailgate to accept the carrier...
I found a nice pic today but can't post it now...
Thoughts?
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old November 20th, 2004, 10:14 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Thanks DJ. I will post up tonight on how it went. Heading over to a friends house to install it right now.
EwS
Old November 20th, 2004, 10:19 AM
take lots of pictures.
Old November 20th, 2004, 06:07 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
I actually didn't take any pictures, during the installation. It only took like maybe two hours. The hardest part was drilling the crossmember. I actually more or less helped out. Mostly the removal of the interior and helping with the placement ect. Buddy of my with air tools an much more experience thankfully lent me a hand.
All said and done, very cool.
EwS
Thanks for everyone's pre-installation help.
Old November 21st, 2004, 01:42 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
EwS
Great! I'm sure you'll be happy with it as it relieves quite a bit of stress from your rear door.
DJ
carrier, installation, mantec, tire, tire carrier
Safari Gard Tire Carrier Joe P For Sale - Parts 10 November 8th, 2005 06:31 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Mantec Swing-Away Tire Carrier david_jackson Defender Technical Discussions 16 December 17th, 2004 05:24 PM
Cheapest MAntec Tire Carrier Nobrega Defender Technical Discussions 5 June 29th, 2004 03:21 PM
