Mantec Spare Carrier Install - Defender Source
Old March 12th, 2007, 03:40 PM
Devin W's Avatar
Devin W
Devin Walton
I'm installing my long overdue Mantec spare carrier and I've noticed that several of the holes on the plate that mounts outside the door and holds the piston that the carrier articulates on do not perfectly match the holes of the plate that was originally mounted there to carry the spare. As far as I can tell there's only one possible orientation for this plate based on the instructions, however, before I slot the holes in the plate to match the ones already drilled in the door I thought I'd check to see if I could be doing missing something here.
Any thoughts from those of you who've already performed this upgrade would be great!
Devin
Old March 12th, 2007, 04:11 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
The plate should mount directly to the holes left from the OEM carrier, but the holes where the piston is affixed should be drilled.
Old March 12th, 2007, 04:31 PM
Devin W's Avatar
Devin W
Devin Walton
Yeah, that's what I thought, but the 4 holes on the left and right sides aren't quite there. Not an insurmountable issue, but a little PITA.
I just took this pic for illustration.
Name:	spare plate.JPG
Old March 12th, 2007, 05:32 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Is it possible if you loosen the screws to slide it up into place?
Old March 12th, 2007, 05:55 PM
Devin W's Avatar
Devin W
Devin Walton
Negatory--tried that and I end up with a bunch of bolts that are sitting at an angle. I just slotted those four holes in the plate. The three central holes lines up perfectly and the position of one of the piston holes place the bolt directly in the center of on of the OE wheel stud holes, so the plate is in the right position.
All done now. Just getting ready to install the spare wheel. Thanks for the responses though. I rarely expect anything to go exactly as described in a set of instructions (when the parts even come with them) with my Rovers!
Old March 13th, 2007, 10:27 AM
Devin W's Avatar
Devin W
Devin Walton
One more question afterall...
I did have one more question on this: Both the top and bottom hinge come with a large steel washer (#21 in the picture) that is supposed to insert between the carrier and the hinge (1 each). Does the washer go on the top or the bottom of each hinge? The instructions don't illustrate the correct placement very well.
Thanks!
Old March 13th, 2007, 12:42 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Hello Devin,
I went thru all this last year...
I placed washers down.
I change all hardware to stainless steel (bolts, nuts, washers, nut plates, etc...)
Also made a long separator for the longest bolt of the lower bracket (to be placed
beetween sides of rear crossmember).
I'm planning to add a couple of greasers for hinges.
It's a great tire carrier, very well designed, just have to tweak it a little...
Let me know if you need pics or something else.
- Charles Eames
Old March 13th, 2007, 12:48 PM
Devin W's Avatar
Devin W
Devin Walton
Thanks, Julien. That's where I put them, but I wan't confident that I had positioned them correctly.
By the way, my kit came with a spacer for inside the crossmember for the longest bolt on the lower hinge mount, so they must have figured that out, too.
carrier, mantec, spare
Mantec Spare carrier clearance question leastonce Defender Technical Discussions 20 December 13th, 2009 08:11 PM
Mantec Swing-Away Tire Carrier david_jackson Defender Technical Discussions 16 December 17th, 2004 05:24 PM
Mantec Tire carrier Installation Questions Eric Siepmann Defender Technical Discussions 6 November 21st, 2004 01:42 PM
4 - 285/75/16's on stock D90 rims, 98% new, also spare & carrier januconn92 For Sale - Parts 7 October 13th, 2004 10:31 AM
Safarigard Spare Tire Carrier mlw911 For Sale - Parts 4 June 16th, 2004 03:29 PM
» Defender Registry
Janey
UserName
88
RProbst
Add your Defender
