Mantec Sliders Gap - Defender Source
Old June 25th, 2010, 05:08 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Mantec Sliders Gap
I have installed the driver's side Mantec slider and I have a gap in the rear section.
First of all is this normal? If not then what have I done wrong and how can I make the gap smaller or go away?
Alex
ID:	28836   Click image for larger version
Old June 25th, 2010, 05:42 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Its a rover
Old June 25th, 2010, 06:22 PM
I had a set on my SW, and they did not line up perfect either, so I guess it is normal. And, I think in is against Defender law to install sliders and a set of steps.
Old June 25th, 2010, 06:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
told her it was super duper gay to have sliders and steps
Old June 25th, 2010, 06:48 PM
So wait now you're keeping your D-90?
Old June 25th, 2010, 07:20 PM
aosias's Avatar
aosias
Alexandra
1995 D90
HA! You said super duper- that's more gay than the sliders and steps
Never said that, it hasn't sold so I'm still tinkering.
Guess the consensous is that they aren't on wrong, I'm just paticular and like things to look nice.
Old June 25th, 2010, 09:26 PM
If you hit a rock on that end hard, it will tighten up the gap. IMHO, gaps are good. I would keep 3/8in-1in all around so when you hit stuff and it flexes, it does not get into the body. Are the holes in front oval on mantecs? You can always move the sill in the front up a bit, the holes on the front of galvanized part of the door sill are oval (at lease on a 110) and there is room to move the captive plate in the foot of the bulkhead.
Ron
Old June 26th, 2010, 06:19 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I think Ron got close, but with the Mantecs I modify the front mount to move the front of the slider down. I have also modified the rear mount and moved them up. I guess the answer to the question is that although they are super duper sliders they don't fit very well.
Matt Browne
Old June 26th, 2010, 08:33 AM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Ron
If built and installed correctly, the sliders should NOT flex,move,bend.... or do anything except protect the truck. If your sliders are moving you have issues.
What tree?
Old June 26th, 2010, 10:18 PM
You have not seen me drive. Put enough load on 2x3 box section and it flexes/bends. That being said, it was mainly said in jest. Hence the
------ Follow up post added June 26th, 2010 10:18 PM ------
Good to know, is that true on 110s as well?
Old June 27th, 2010, 07:06 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
dunno.....I've never used them on a 110.
Matt Browne
Old June 29th, 2010, 08:41 PM
KKilo23's Avatar
KKilo23
Kenny
I have the same gaps on my 90 SW...
mantec, slide
USed Mantec Sliders aosias For Sale - Parts 1 May 21st, 2010 10:37 AM
Mantec Rock Sliders Defender13 For Sale - Parts 5 July 22nd, 2006 05:38 AM
DIY Rock Sliders kellymoe Defender Technical Discussions 3 December 22nd, 2005 07:10 PM
Best Rock Sliders for a D-90? Seriesman Defender Technical Discussions 9 July 16th, 2004 11:41 AM
