Mantec Question - Defender Source
Old May 9th, 2009, 12:16 AM
bjf's Avatar
bjf
barry f
94 ST #395
Mantec Question
I put my mantec on tonight. Really happy with it. Quick question. For the top hinge, you drill out the top rivets in the capping and put the bolts through. Do I need a stiffening plate behind the capping on the inside or is the nyloc nuts good enough?
Old May 9th, 2009, 12:34 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I just used washers. There are several layers of metal there, with additional stiffening provided by the proximity of the bends in the capping. I think it will be more than strong enough, but if you wanted to put something in there, I would just get a piece of bar stock and drill it out for the bolts.
Old May 9th, 2009, 11:06 PM
Chaucer
Will
93 110 | 97 90
Not sure if one is needed, but Mantec ships the carrier with a backing plate as part of the kit. The backing plate has the two M10 nuts welded to it. Andrew's method sounds like a good solution.
Old May 10th, 2009, 01:17 AM
bjf's Avatar
bjf
barry f
94 ST #395
mine didnt have it
mantec
Mantec Spare carrier clearance question leastonce Defender Technical Discussions 20 December 13th, 2009 08:11 PM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
