Mantec Carrier on a Soft Top - Defender Source
Old July 1st, 2010, 10:45 AM
jumpcutter's Avatar
jumpcutter
94 D90 #0252
Hi Everyone,
I was born into the D90 world about two weeks ago- pulled the trigger on a 94 AA Yellow soft top and I couldn't be happier! I finally divorced my 93 YJ and found a prettier girl!
I've looked through hundreds of posts regarding the Mantec carrier vs Bearmach vs .... and I'm not trying to start a thread of which is better.
I have yet to see either one hanging off the back of a soft top tailgate. Can anyone tell me if there are any issues I might run into with the half door?
Thank you and Happy 4th!
Old July 1st, 2010, 11:25 AM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
The ST tire carrier is very good and generally doesn't cause problems.... there are a few specific reasons to go with something else for the ST but unless you run into those cases stick with the oem carrier...
Old July 1st, 2010, 11:27 AM
jumpcutter's Avatar
jumpcutter
94 D90 #0252
Thanks, but I should have mentioned in my original post that my truck was missing the OEM carrier when I bought it. Sorry
So far my search has come up empty.
Old July 1st, 2010, 11:53 AM
You need a couple spacers for the tailgate. Other than that, my understanding is it just bolts right up.
Old July 2nd, 2010, 08:21 AM
Jase
Jase
pending
90% certain that the Mantec carrier will cause interference issues with the lip the ST uses where it bolts to the top capping. You may need to adjust the lip rail or not correct the top in that area. Clearly I'm not positive but look closely where the Mantec bolts up and where the rear, pass side, top lip rail is positioned.
carrier, mantec, soft top
1997 Bestop Soft Top Like New & Misc Parts Adam Armendariz For Sale - Parts 16 December 8th, 2005 01:43 AM
Soft Top Rear Tire Carrier dannr09 Wanted 1 August 3rd, 2005 08:21 AM
SG Tire Carrier On A Soft top WITH Rack thelandroverguy Defender Technical Discussions 3 March 18th, 2005 09:02 AM
Soft Top Tire Carrier javelinadave Wanted 3 November 15th, 2004 03:06 PM
Which is the best soft top for D-90? bbandit Defender Technical Discussions 13 March 9th, 2004 08:40 PM
