manifold gasket 300tdi - Defender Source
Old January 29th, 2011, 07:17 PM
Suspected my gasket was shot by the amount of oil built up around the intake. I was right...
Old January 29th, 2011, 11:33 PM
looks like the one that we took off of mine this time last year
Old January 30th, 2011, 11:13 AM
From poking around the web it seems to be a pretty common failure mode. I suspect caused by torquing down the exhaust manifold first and then the intake. I torqued all the fasteners from the center outward. That precludes using a torque wrench but then again I've never been able to use one on any of my other engines' manifolds so I guess tight will have to suffice.
Old February 1st, 2011, 06:26 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
There are a few different type of gaskets that you can use. I found an all metal one that is said? to be better?
Land Rover 110
Old February 1st, 2011, 07:58 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
From what i remember the metal one is the correct replacement, but i'm not 100% sure.
- Charles Eames
Old February 1st, 2011, 10:31 AM
Not sure if was the metal one you speak of but it was a new one from RDS as pictured on their site. The vehicle is much quieter now and seems to have a bit more power in the top end.
Old February 1st, 2011, 01:19 PM
Capt Milks's Avatar
Capt Milks
I had the option of getting a fiber one or metal when I ordered mine. I have used both with success.
Land Rover 110
Old February 1st, 2011, 02:03 PM
this is what I got:
Old February 1st, 2011, 02:07 PM
You sure thats your engine or did you snipe that shot off of google images ? looks too clean.
Old February 1st, 2011, 02:16 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Remember to change you plastic coolant thermostat housing filling screw with a brass one, the one on the radiator also. Easy to find on eBay.
- Charles Eames
Old February 1st, 2011, 02:48 PM
Not my engine- photo grabbed from another website. I did change those plugs the same day I changed the gasket. Always carried two spares of the plastic ones up until this point.
Old February 1st, 2011, 02:50 PM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
Just did this on mine. The plastic ones seem to have an o-ring, but the brass ones don't. Should I have fitted one? They don't seem to leak as is.
Also wish I had found nicer hose clamps than the ones I used
-Gardner
Old February 1st, 2011, 02:55 PM
mine came from RDS with O ring. good and cheap!
-Gardner
Old February 4th, 2011, 06:49 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I wonder if my gasket is in the shape yours is - the EGR block-off plate didn't have a gasket on it, and it was leaking oil when I first fired up the motor in my truck... I put a gasket on, but was concerned by the amount of oil running down there. What do you think?
Old February 4th, 2011, 06:53 PM
check the turbo shaft for play?
300tdi, gas, tdi
300Tdi exhaust manifold problems crown14 Defender Technical Discussions 12 July 8th, 2009 11:38 AM
300Tdi Exhaust manifold elbows JSQ Wanted 1 June 8th, 2009 05:31 PM
Should it cost $1000 to replace my intake manifold gasket? phoenix37 Misc. Chit-Chat 7 July 9th, 2008 07:25 AM
Place your bets, Blown head gasket, or cracked manifold? Hans Defender Technical Discussions 12 March 20th, 2008 08:02 PM
