Manifold/exhaust heat wrap - Defender Source
Old April 2nd, 2008, 02:40 PM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
Does anyone have any experience, advice or warning using Heat Wrap on the manifolds and exhaust? Is there a risk of damaging anything or is it just a lot of work with little benifit?
I'm about to try it to use it to reduce under-bonnet and floor board temperature.
Thanks!
Owen
"I think you need a little weatherstripping - right here..."
Old April 2nd, 2008, 03:21 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
The biggest issue is that it can tend to hold in moisture and cause rusting. More of a problem with headers than cast iron manifolds.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 2nd, 2008, 06:09 PM
owen's Avatar
owen
Owen Jones
Good point, hadnt thought of that. Although I am running a full stainless steel exhaust that should slow that down a tad.
Thank for the input.
I guess my concern was more about running the manifolds red hot while bolted to aluminum heads...
exhaust
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
Heat Sheild Bowtracer Defender Technical Discussions 14 July 7th, 2007 12:11 AM
Heat insulation blankets kellymoe For Sale - Parts 1 July 13th, 2005 04:54 PM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
