Manifold - Defender Source
Old January 27th, 2014, 09:53 AM
terminus
CHRISTOPHER
1984/D90
Manifold
I have a 1984 D90 2.25 Petrol. Someone before me did a change out on the manifolds. I can not find a stock intake so the exhaust has to be machined down to fit under the existing intake leaving the walls so thin it caused it crack and burnt a hole in it. I bought a Pierce manifold and matching Weber carb but could never get it to run after a year of tinkering with it.
This 90 always started and ran well until I started this project. Does anyone have any suggestions other than machining the exhaust manifold down?
Old January 27th, 2014, 10:20 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Are you looking for another 2.25 intake? Cause I have one if you need it? Infact I have an entire parts engine, the block is toast but rest is good.
Old January 27th, 2014, 10:55 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I have the stock manifolds for that engine/vehicle/combo that takes the weber 2 barrell.
RDavisinVA
Old January 29th, 2014, 09:16 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
I ran a Pierce Manifold with a 2 barrel Weber on a 2.25 petrol for years and it's a great setup! The pistons were 30over with 2.5 cam. I never liked the stock exhaust manifold. I used a custom exhaust header and bent a 2 1/4" custom exhaust. Very quick and will do 65-70 mph without issue. Downside is 12 -15 mpg on a good day
Good luck
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Whistle noise from exhaust manifold? markurski Defender Technical Discussions 11 November 27th, 2007 08:39 PM
Late model intake manifold on 3.9? jaherring Defender Technical Discussions 11 October 31st, 2005 11:16 PM
Exhust manifold Campbell Defender Technical Discussions 7 August 13th, 2005 10:35 PM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
a one carb manifold for the V8 engine DIVERPRO Defender Technical Discussions 3 March 9th, 2005 11:46 AM
