Man trans & t-case fluids - Defender Source
Old February 4th, 2007, 03:42 PM
dnp
David
1995 Defender 90
My '95 D90 ST didn't come with an owner's manual. Hope I haven't overlooked a thread somewhere, because I've done several searches and looked at the FAQ's, and I can't seem to find a consistent answer to these questions:
1. Does the manual transmission on a '95 call for gear oil or ATF?
2. What weight of either?
3. It looks like the t-case calls for gear oil right?
4. What weight for this?
My confusion stems from threads where some people said they were using gear oil in the tranny and others where people said they were using ATF. Due to the huge difference in viscosities between the two, I wanted to make sure I changed out to the proper stuff (in both boxes)
Thanks in advance for any clarification on these issues.........
Old February 4th, 2007, 08:49 PM
REDLINE MTL in your gearbox!!! any cheap 90 weight in your transfer case as it will probally leak out.
Do a search for Redline MTL, its the best.
Old February 4th, 2007, 11:06 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
MTF94 for Transmission, synthetic 75W90 for Transfer case.
- Charles Eames
Old February 5th, 2007, 10:27 AM
http://www.redlineoil.com/products_g...7&categoryID=7
Redline MTL for your transmission.
Any 80w90 or 75w90 gear oil for the t-case.
Old February 5th, 2007, 10:55 AM
dnp
David
1995 Defender 90
So gear lube rather than ATF in the tranny huh? Ok, well how many quarts does the tranny in a '95 hold?
Thanks.
Old February 5th, 2007, 11:50 AM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
Is the MTL thin enough to go through the oil pump ok at low temps? I drive my 90 in temps as low as -40C some times and -20C is common.
Old February 5th, 2007, 11:55 AM
No gear lube, you have to use MTL, which although speced as a gear lube, is thinner than normal gear lube. The original spec was ATF, but rover updated it for the rest of the world to Texaco MTF which is nearly identical to redline MTL.
To headdamage, I would use straight synthetic AFT for those temperatures, but in 10 degrees F MTL was fine after a minute or two so I think you would be ok.
Ron
Tranny holds between 2 and 3 quarts. Like 2.5 or 2.7 something like that.
Old February 5th, 2007, 12:27 PM
dnp
David
1995 Defender 90
I've used Red Line products before (not MTL, but their engine oils and gear lubes), and I've been very pleased.
Thanks for the specs./capacity. I'll order some MTL right now.......
dnp
Old February 5th, 2007, 12:55 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
SynchroMax for Royal purple works well. Napa carries RP
Old June 8th, 2007, 09:25 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
Has anybody tried the MTF oil from Amsoil in an R380? Amsoil claims it "Replaces MTF-94 fluid for Land Rover, MG, and Mini Cooper. Replaces Honda Genuine MTF fluid for manual transaxles and Texaco MTX fluid."
http://www.amsoil.com/StoreFront/mtf.aspx
Brett
Old June 8th, 2007, 10:21 PM
I use the Redline, its so good I wouldnt try anything else.
Old June 8th, 2007, 10:24 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
Seconded. This stuffs so sexy there`s no point in messin round with anything else.
Old June 9th, 2007, 08:40 PM
moose's Avatar
moose
Brett
Ok, I was just curious if anybody had used the Amsoil product. It and the Redline MTL are both available nearby.
I got some Redline this morning.
Brett
Old June 10th, 2007, 09:41 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
thats cuz you don't know anybetter sorry to say! they are all a very good product
Old June 11th, 2007, 02:37 AM
oldscratchggf
nate
95 d90
Way to be a self-righteous dick. Not only is that a pretty bullshit call on your part, but could you find a more arrogant and condescending way to phrase it? What would you know of my experiences? I went through 3 (yes, that`s right, 3) R380 transmissions in my 1995 D90 due to BTS Transmissions in Campbell, Ca trying all forms of ATFs (per Land Rovers recommendations), gear oils (per the 2 transmission rebuilders recommendations) and 2 other MTFs before getting it right and using the only fluid that did not cause issues with the synchros, which was Redline MTF, which was the third MTF we tried. RP and Amsoil MTFs worked decently well, but were not nearly as smooth feeling, and were far rougher while running through the gears. I understand that it varies to a certain degree based on climate and driving style, but I swear by Redline, and that`s that, so keep doggin on me buddy.
On that note, stay away from BTS Transmission in Campbell, California.
I neglected to mention too, that there was far more brass in the fluid after draining the Amsoil and RP than there was after draining the Redline.
Old June 11th, 2007, 10:25 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Ya I could have said your a dumb fuck!
now there's some science
Old June 11th, 2007, 04:13 PM
oldscratchggf
nate
95 d90
Calling my a dumb fuck while using "your" instead of "you`re" kind of negates your comment, and with the way you phrased it to begin with, you may as well have just said that in the first place. Fuckin prick.
Old June 11th, 2007, 07:30 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Easy Rambo! I didnt call you a dumb fuck! I could have but didnt! I have been called wosre by better anyway. I still don't think you know what your talking about in regards to MTL's.
Pickin on my grammer is a layup!
Old June 11th, 2007, 10:00 PM
oldscratchggf
nate
95 d90
What is there for me not know? I tried RP, Amsoil and Redline and the smoothest MTL with the least brass in it when drained was Redline..... So tell me, what else do I need to know? Seriously? Shool me
Old June 11th, 2007, 11:51 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
i just put in MTL and it is soooo smooth. though i haven't tried anything else to compare. Ron suggested MTL and man was he right
howling trans or Transfer case? Gkase Defender Technical Discussions 18 February 8th, 2008 11:08 AM
Rover Expedition Case w/ 4 walkie talkies jack frisch For Sale - Parts 0 February 27th, 2005 03:24 AM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
» Defender Registry
90
clb1994
Gruff
Stormer
Add your Defender
