mallory wiring help - Defender Source
Old May 12th, 2013, 02:43 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
mallory wiring help
If you are using a stock coil with your mallory distributor, how are you routing your wires? I am still getting an intermittent surge and I am wondering if I cam doing it correctly. I see the factory routing, with both the red distributor and ignition wiring going to the ballast resistor (which is what I am recently doing)and then to the + coil, and I have heard others with the ignition only going to the ballast resistor (and continuing to the + side of the coil) and the red wire from the Unilite module going directly to the + coil..
Curious how others are doing it.
On my negative, I have the green wire and the wire for the tach/ecu...
wiring
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Aux Light Wiring Frustratio ronward Defender Technical Discussions 4 August 23rd, 2004 06:53 AM
D110 Stereo wiring pcarey Defender Technical Discussions 1 November 23rd, 2003 10:57 PM
