Mallory Unilite Problems Continue - Page 2 - Defender Source
Old November 17th, 2013, 11:05 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
FWIW, I had a friend install a Mallory Unilite Distributor. It worked for a while but then started having random stuttering & misfires. We found that the breaker plate had no ground wire....it was expected to ground through the 3 ball bearings that it rotated on. We added a ground wire from the distributor body to the breaker plate and it has run correctly ever since. Might be worth checking if you have a unilite.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old November 18th, 2013, 06:27 AM
Maybe manually rotate the crank a little.
problems
Question about Mallory Unilite distributor & Coil combination compatibility Neil McCauley Defender Technical Discussions 52 July 15th, 2016 08:38 PM
Mallory UNILITE tgraham Defender Technical Discussions 10 August 21st, 2009 11:18 AM
Major Wire problem-- dash dissasembly. Need help. Ignition Mallory Unilite Heath Defender Technical Discussions 22 August 29th, 2007 12:35 PM
Mallory Unilite Distributor Davis Defender Technical Discussions 5 April 9th, 2005 05:00 PM
Driveline (shaft) problems continue... P1CR Defender Technical Discussions 2 July 16th, 2004 10:39 AM
