Mallory unilite coil dead - Defender Source
Old October 27th, 2012, 01:16 AM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
Ive installed a Mallory unilite distributor and coil in my truck, from what I had read it appeared that I would not need to purchase a ballast resistor or anything else. So I just installed the pair... The first coil lasted about three weeks then died, the second one was second hand off a buddy and died in a week... Both times the truck was running at low rpm and just cut out...
So any suggestions?
Do I need a ballast resistor, do I need a power conditioner?
Some grumblings have mentioned the alternatoras the source of my woes... What say the gods... More poor truck is stranded at Walmart. I told my wife it was like bringing a victoria secret model to hooters...
Old December 10th, 2012, 08:20 PM
Verner Berry's Avatar
Verner Berry
Verner Berry
97 D90
I don't have an answer but a question. I am trying to install a Mallory in my RRC 3.9, did you have a "hot" wire going to the coil from somewhere on the truck? The reason I ask is that because the OE distributor is magnetic and the Mallory has the optical eye the coil would need power from somewhere (12v) Any help would be greatly appreciated.
VB
coil
Question about Mallory Unilite distributor & Coil combination compatibility Neil McCauley Defender Technical Discussions 52 July 15th, 2016 08:38 PM
Theoretical ? regarding a mallory unilite distributor, coil and battery. Neil McCauley Defender Technical Discussions 16 December 16th, 2010 06:22 PM
Mallory Distributor, Coil, Magnecor Wires, ect. Paul Grant For Sale - Parts 0 November 15th, 2007 08:03 PM
Major Wire problem-- dash dissasembly. Need help. Ignition Mallory Unilite Heath Defender Technical Discussions 22 August 29th, 2007 12:35 PM
Mallory Unilite Distributor Davis Defender Technical Discussions 5 April 9th, 2005 05:00 PM
