Mallory dizzy question - Defender Source
Old April 3rd, 2013, 03:35 PM
wantone
Rick Thompson
94 ST #1222
I am ordering the mallory dizzy/coil combo. Does the dizzy drop in or does the gear on the end need changed? Thanks
Old April 3rd, 2013, 03:40 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
It comes without the drive gear (but did come with the rollpin needed for it as I recall), so you'll need to either swap over your old drive gear or buy a new one and mount it. You'll also need to drill a hole through the end of the dizzy shaft,. All of this is pretty easy and the dizzy will come with good directons.
I'm happy with the setup on my 94.
Good luck!
Murph
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old April 3rd, 2013, 03:45 PM
wantone
Rick Thompson
94 ST #1222
Thanks chris! Do you have the coil 30451 too?
Old April 3rd, 2013, 04:15 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
I forget which part # coil I bought, but I did buy one of the Mallory coils at the same time, the model that Neil here on the site has written about a bunch as he installed and used the same setup.
Before you order, I recommend doing some web searching for these, as the prices can be all over the map. I ended up buying it all on Amazon, which I recall at the time was less than half the price of some other online sellers.
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
Old April 3rd, 2013, 04:20 PM
wantone
Rick Thompson
94 ST #1222
thanks so much! yeah, i saw on amazon you can get them both for about $400
Question about Mallory Unilite distributor & Coil combination compatibility Neil McCauley Defender Technical Discussions 52 July 15th, 2016 08:38 PM
Question regarding oil drive gear on the Mallory Unilite distributor Neil McCauley Defender Technical Discussions 4 December 27th, 2010 05:59 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
