Mallory Distributor help needed - Defender Source
Old June 28th, 2014, 08:30 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Hi All. I'm back at it, working on my '94 D90.
A year or two ago I came to the determination that I needed to replace the distributor. I chose to go with a Mallory. A friend of mine helped me swap out the gear. I think I forgot to add this washer (see image). A year later, I have no idea if it existed, or if I misplaced it. Any help will be greatly appreciated.
Last year I had some links to sites that walked me/buddy through swapping out the gear, which involved drilling the hole. Does anyone have that link? Yes, I searched like crazy before posting.
Thanks everyone! I'm psyched to be back at it. Dying to have this thing cruising soon.
Old June 28th, 2014, 09:53 PM
I'm guessing it was the dead link from post #7. Maybe one of the San Diego guys has it in hard copy. http://www.defendersource.com/forum/...ad.php?t=14742 Also, Rij just put one on his truck. Maybe he can chime in. -Jeff
I drilled the gear hole ... Don't follow our method ... Do it properly ... A pedestal drill is needed.
Old June 28th, 2014, 11:31 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
I think I found a link that will help... http://www.v8engines.com/faq-mall.htm#internal
I need to figure out the thickness of the washer above the gear.
Thanks everyone.
Old June 28th, 2014, 11:46 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
The image in this link might show that it didn't have a washer... this is killing me. Any risk of installing without the washer?
http://www.roverparts.com/Parts/8832KA
Old June 29th, 2014, 03:24 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
-Jeff
Thanks Jeff. Good thinking. I emailed the San Diego guys. I appreciate the help. Hoping they write back while I'm still focused on this project..haha.
Anyone else? Thrust washer for a 94 D90?
Old July 2nd, 2014, 08:10 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Update from our west coast friends at Rover Works:
Steve,
The newsletter is from Oct/Dec 2007. Vol. 9, No. 4.
The washer (shim) is 0.020 thick. Also, don’t use the Mallory coil. We have had issues with these. Use the stock coil and the ballast resistor.
Old July 2nd, 2014, 01:55 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by EnduroPro View Post
Update from our west coast friends at Rover Works: Steve, The newsletter is from Oct/Dec 2007. Vol. 9, No. 4. The washer (shim) is 0.020 thick. Also, don’t use the Mallory coil. We have had issues with these. Use the stock coil and the ballast resistor.
Interesting about the stock coil and ballast resistor. I went thru a few Mallory coils including the upgraded/HD one with the aluminum fins. Not sure if I used a washer either. What would be the downside if not running one?
Old July 5th, 2014, 04:16 AM
skrufy
Tim Timmins
1987/Defender 110
I've had the Mallory distributor and the matching Mallory Coil in my '95 3.5L D1 for several years now without any issues, other than frying the pick-up module thru my own fault. The beauty of the matching Mallory coil is an easier installation and no ballast resistor needed. I also installed the matching Mallory inline electronic filter to protect the pick-up module from electrical voltage spikes or surges.
NEVER use the "Engine Start" feature on a battery charger on a modern vehicle equipped with lots of computers and control modules. The raw power from the charger in the "Engine Start" position gives a very "dirty" electronic signal or spike that will fry anything delicate = your expensive ECM, etc. I am not an electrical engineer, but that is what was explained to me by one.....
I can get the Mallory part numbers and post them later this weekend.
Tim
'95 D1
'87 Defender 110 300Tdi
several 911s......
distributor
Mallory Distributor HELP! Verner Berry Defender Technical Discussions 9 December 15th, 2012 02:59 PM
Mallory distributor and other parts for sale tmore For Sale - Parts 3 February 7th, 2007 09:56 PM
mallory distributor jonny wrench Defender Technical Discussions 0 April 23rd, 2006 03:20 PM
Mallory distributor tmore Defender Technical Discussions 13 April 21st, 2006 10:09 AM
Mallory Unilite Distributor Davis Defender Technical Discussions 5 April 9th, 2005 05:00 PM
