I'm about to swap out my old troublesome Lucas dizzy for a new Mallory Unilite unit. Does the Unilite have an embedded ignition module or do you have to figure out a way to use and mount the old stock unit?
Any other pointers you guys have for me on this conversion?
I'm going to install the active power filter and the ballast resistor. Can anyone confirm that you do actually need the ballast resistor if you are using your stock coil?
YES! use the ballast or else boom goes the coil I've had my mallory for 2 years and have had no problems and I don't even have to knock on wood because it's a good product
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
