Making up steel braided lines... - Defender Source
Old November 23rd, 2009, 10:55 AM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Any hints on how to get the end caps on steel braided lines? I am making up my own oil cooler lines and the Russell instructions are like "simply push with a twisting motion" ....eh ya right....
B
Old November 23rd, 2009, 11:50 AM
Grover's Avatar
Grover
I would recommend having a hydraulic shop crimp the fittings to your oil cooler lines.
Cheers...
Old November 23rd, 2009, 12:21 PM
I've wrestled with these a few times...
My best advice is to find the Koul Tools AN Hose assembly tools. These are available from Summit, Jegs, etc. They make assembling AN hose a far less "prickly" affair.
You should also borrow or buy a Dremel with reinforced cut wheel attachment. Wrap the area to cut with two wraps of masking tape or strapping tape. Carefully and slowly cut thru the hose so you make as few fish hooks as possible. Gently unwrap the tape...dip the end in oil...shove mightily into Koul Tools assembly tool, twisting the hose as you go.
The smaller you go the more difficult it is to assemble. 4AN is a real pain and 3AN brake hose assembly...well, it is nearly impossible.
I could loan you my set of Koul Tools, but you'll have to wait until the weekend after next.
Old November 23rd, 2009, 12:45 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Thanks. I saw those and was wondering whether it was worth the purchase. I have to grab some other stuff from Summit anyways so I might as well at least get the adapter for the 8AN, which is what I am working with.
B
Old November 24th, 2009, 07:49 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
I recommend getting the specially made vise jaw grips to hold the fitting, then push and twist.
stainless steel fuel, brake, oil lines ditskovich Defender Technical Discussions 4 April 6th, 2009 07:01 PM
Making AC Lines Lesandjes Defender Technical Discussions 3 July 10th, 2008 12:58 AM
stainless steel brake lines bulk purchase 1000kva Misc. Chit-Chat 0 July 9th, 2006 12:54 AM
Oil Cooler Lines - braided, SS DanK Defender Technical Discussions 8 May 13th, 2006 08:59 PM
Stainless steel extended brake lines Chris Cox For Sale - Parts 1 February 8th, 2005 01:34 PM
