Making Aluminum Shiny - Defender Source
Old August 4th, 2011, 12:51 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Does anyone know a trick to make aluminum shiny? I was hopping for a chemical or cleaner of sorts. I don't have the time to polish / buff them out, and I really don't want them that shinny. Just new looking.
The valve cover on the right has been cleaned in chem dip. It is very clean but looks stained.
The valve cover on the left I bead blasted which is a huge improvement but not shiny like a new one.
I'm not looking for chrome shiny just new cast aluminum shiny.
ID:	40855   Click image for larger version
Old August 4th, 2011, 01:10 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Other than paint it require elbow grease. If you don't want to buff it and are not looking for a real shine , you might try; http://www.nevrdull.com/. It's cotton so it is easy to use and gets into the crevices.
Old August 4th, 2011, 01:20 PM
James Pierce
James Pierce Jr.
I've seen my father use that on the aluminum fenders on his truck. I'll have to give it a try.
This is what I'm going for... Something like the bottom of the manifold that hasn't been exposed.
Old August 4th, 2011, 01:28 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
There is a better product called Wenol works great on about any metal.
Old August 4th, 2011, 01:38 PM
if you aren't looing for a super polished finish, just use a buffing wheel on a good fast drill (after bead blasting). They should clean up fairly quick maybe 30 minutes per side?
Old August 4th, 2011, 01:44 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
That Wenol stuff is suppose to be the shit been under the radar for years(?) untill recently. You could only find it at truck stops and motor cycle stores but now you can find it at most auto stores now. Also might want to check out the Garage Journal forum as they have some pretty simple ways of doing things and getting awesome results.
Old August 4th, 2011, 01:53 PM
The Dro
Dro
1988 Ninety
I remember this company from a Speed channel episode... I've never used it, but it looks to be what you need.
http://www.sharkhide.com/acinfo.html
You might want to media blast the cover first.
Old August 4th, 2011, 01:59 PM
Have it soda blasted
Old August 4th, 2011, 02:20 PM
I think you are looking for stuff called Alumabrite. Weak acid of sorts, works well for cleaning up castings. Bought some @ NAPA.
https://www.napaonline.com/Catalog/R...&Dk=1&Dp=3&N=0
Old August 4th, 2011, 02:57 PM
kevkon's Avatar
kevkon
kevin
Problem is that he has already beadblasted one and chemically dipped the other, so cleaners are not really the answer. The only thing that will brighten will require either blasting with a finer abrasive and/or some type of buffing. The phosphoric acid ( Alumabrite) might work to some degree.
Old August 4th, 2011, 03:09 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Heat resistant paint or fine sanding.
- Charles Eames
Old August 4th, 2011, 06:46 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Mother's Aluminum Polish.
http://www.mothers.com/02_products/05100-05101.html
Nevermind, you don't want to polish.
Old August 4th, 2011, 08:15 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
X2 on that stuff. Cleans aluminum and also copper very well. But once you blast it you have altered the finish including any machine polish from the factory.
Old August 4th, 2011, 09:46 PM
JBinAlabama
john
Series 2A ..more parts on the way
I just got some stuff called "woody's" from marine store to polish my cobra wind sheild frame.
I was told its the best for this but I have not had time to try it yet.......but soon
Let us know what works!
Old August 4th, 2011, 10:53 PM
James Pierce
James Pierce Jr.
So far I've come to the conclusion that the parts go under the hood of a rover. They are not meant to be shiny and clean, and if they were they won't stay that way for long. So why am I wasting my time with this? I'll let you know when I figure that out
I went to O'Reilly's and picked up some Mothers aluminum polish and to Napa and picked up the Aluminum Bright. Neither had the Wieneroil or whatever you call it. If I am able to find it I will try it later and report back.
First the Mothers. Don't waste your money unless your 22's have some brake dust on them. It's probably a good product but not for this application. I don't think it would work well on cast aluminum that isn't already polished.
Second the Aluminum Bright does work. While maybe not in the first application and maybe not in the 20-30 seconds it says on the bottle it does work. In the first pic I coated the Left half of the valve cover with the AB and it didn't do much with one application. It preforms very similar to the sharkhide based on the video. Probably similar chemicals.
In the second pic the valve cover on the right has been scrubbed (a lot) with the Aluminum Bright and a fine scotch bright pad. The valve cover on the left has been bead blasted.
The glass beads, however fine they may be, do change the texture of the surface. They make the aluminum cleaner and brighter than the Aluminum Bright with a lot less effort but they do open the pores up and this leaves a rougher finish which I feel in time would only attract dirt quicker and be harder to clean off. So tomorrow I will head out to find a buffer / polisher to see if I can close up the pores and bring it back to its Solihull glory.
Thanks for all the input!
ID:	40860   Click image for larger version
Old August 5th, 2011, 07:11 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I'd hand that off to shopgirl. She can pretty much buff anything out. There is no substitute for hard work if you need to have shiny bits.
Matt Browne
Old August 5th, 2011, 09:20 AM
James Pierce
James Pierce Jr.
Smooth how you changed GF to shop girl Just incase she's checking up on your post Or was that a freudian slip? I wonder if Steve's Wholesale carries ship girls on the same isle as the buffers. This thread is going down hill fast.
Old August 5th, 2011, 10:24 AM
Back in my paintball days, when we had guns go out for anodizing, we would have them buffed as part of the initial process. Machining marks on the aluminum bodies down to perhaps 400 grit could be mirror polished.
The only way to get that "mirror polished" look was buffing wheels and successive levels of buffing compound. I saw photos of anolaze's buffing area and it's pretty serious. They sometimes blasted parts before buffing.
I've heard of electropolishing but that's for very fine polishing (like making hand-buffed components even more smooth)
Old August 5th, 2011, 11:18 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
yup ...that was a slip for sure.
Matt Browne
Old August 5th, 2011, 11:41 AM
Valve covers look good. Next time mine come off they are getting polished for sure as is Plenum. Good post thanks.
aluminum
FREE D90 Aluminum Roof Panel Roadsiderob For Sale - Parts 13 February 15th, 2006 11:38 PM
Aluminum HT w/lift gate & internal SD roll cage jabber For Sale - Parts 21 December 21st, 2005 12:36 PM
Full Aluminum Hard top and Rear Door Buckon37s For Sale - Parts 12 April 7th, 2005 10:02 PM
Full soft, fiberglass, or aluminum top needed ember Wanted 3 February 18th, 2005 01:27 AM
stripping aluminum mattdh Defender Technical Discussions 2 November 10th, 2003 03:19 PM
