Making AC Lines - Defender Source
Old July 9th, 2008, 01:52 PM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
Making AC Lines
Trying to get the AC working in my NAS D110. I plan to drain all refrigerant, flush/clean and remove whatever blockage I seem to have, complete the R134 upgrade with new pressure switch and drier, put to vaccum, and add new refrigerant. Already checked the compressor and replaced the AC belt. It runs now and blows some cold air but not alot and AC manifold readings tell me I have a blockage in the system somewhere.
I ordered a new drier from AB with the upgrade kit. Problem is that the new one has a pressure switch but no AC lines with it. The old one has hardlines welded into the drier. SO I need to make new AC lines for the new drier.
I see online sources for AC stuff (lines, crimpers, etc..) but I am not convinced that I can get rubber lines to bend the way I need the new drier lines to bend to attach to the condensor and such.
Anyone know if you can fab up lines with copper or other metal materials? I found out LR sells a direct replacement drier/switch and it costs............over $800 from the dealer. No way I am going that route. The AB drier/switch should be fine with new lines thus my question.
AndrewT
'93 NAS D110 #437
Old July 9th, 2008, 04:05 PM
The best bet for you is to head down to your nearest Thermoking and get them to fab you a set of lines. They are used to repairing refrigerations units at all hours, so they are typically very convenient and reasonably priced. The aesthetic quality of the work will depend on the guy that does it, but it will always be functional. At one TK I went to, the guy was an artist, another time it was a "git er dun" job. Both hoses were under 100 dollars.
Old July 9th, 2008, 04:59 PM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
Thx Jim.
Thermoking by me said they cannot make AC lines??? They referred me to another place that I am calling now. Appreciate the suggestion.
Andy
'93 NAS D110 #437
Old July 10th, 2008, 12:58 AM
Its summer, the busy season, maybe they didn't want the hassle. At least they gave you a point of contact.
ac
Making up steel braided lines... wcampbel@nas.edu Defender Technical Discussions 4 November 24th, 2009 07:49 AM
Transmission cooler lines?!? tron Defender Technical Discussions 2 September 29th, 2005 08:39 AM
Dynaflex Synthetic Winch Lines Starting @ $280.00 RedRhinoProducts The Vendors Loft 1 November 4th, 2004 09:07 AM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
