Make shift hi-lift ARB mount - Opinions? - Defender Source
Old September 18th, 2005, 11:13 AM
Antonios
Antonios Hadjigeorgalis
No more
Ok I just need this to hold on my way to Miami from Baltimore, 1100 miles on 95S.
Those are steel pipe straps and there is no play at all. I'm going to drive it around for a test drive to make sure they stay that way before I leave.
I'm leaving tommorrow so I don't have a lot of time. My other thought was to get some large grade 8 bolts and bolt it to the top of the bar through some existing mount holes.
I thought I would run this by you guys to get a second opinion. I won't have room inside because I'm going to have the it packed full of other stuff.
ID:	3859   Click image for larger version
Miami, FL
Old September 18th, 2005, 11:44 AM
I would throw a heavy rubber bungy on it as a backup in case the pipe clamps fail.
Old September 18th, 2005, 01:32 PM
Antonios
No more
Well I couldn't leave it crooked like that so I bolted it to the winch mount holes below the liscense plate. It's nice and tight and looks pretty professional. I'll probably leave it there until I get a winch.
Miami, FL
Old September 18th, 2005, 11:01 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
sounds like a good move, those hose clamps looked scary. Nothing like having a 50lb hi lift go flying through your windsheild at 70mph.
Old September 18th, 2005, 11:08 PM
MAKE SURE THE HANDLE IS SECURE! Thats why I said bungy around it. the handle on mine came out of the base before and it swivled on the pin I put throught it at the other end until it was pointing streight forward and only hanging on by a thread at 75 mph. If it came off I don't know where it would have gone but at the least I bet it could have punched a big hole in the radiator, or worse the windsheild and hit the dummy driving.
mount
Hi Lift Bumper Mount thelandroverguy Wanted 0 January 10th, 2005 12:25 AM
D90 ARB front bumper w/ winch mount taoseno For Sale - Parts 17 October 14th, 2004 11:32 AM
D90 ARB front bumper w/ winch mount taoseno For Sale - Parts 0 August 10th, 2004 01:41 PM
Hi lift mount Britt Easterly Misc. Chit-Chat 6 May 5th, 2004 06:19 AM
High lift mount! TwisteD90 Misc. Chit-Chat 10 December 15th, 2003 02:35 PM
