Maintenance for new truck - Defender Source
Old May 16th, 2016, 04:54 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
While awaiting my new truck to arrive, I want to start procuring all maintenance items needed to help ensure a positive experience. Truck is a 91 D90 200 TDI.
Is the Pro Line branded stuff any good? Or should I buy OEM? I.E. Filters and valve cover gasket
Ill take any and all recommendations you have for me
  1. Engine Oil - Shell Rotella 5W-40 - 6.7 liters
  2. Oil filter extra capacity (Rovers North ProLine OK?)
  3. Front and rear differential + transfer case fluid - 6 liters 75W-90 (Motul Gear 300)
  4. 2x magnetic drain plugs for differentials
  5. Transmission fluid - Redline MTL 3 quarts
  6. Transmission filter (LT77)
  7. Coolant
  8. Brake fluid - 2 liters DOT 4
  9. Timing belt kit (Rover North kit)
  10. Timing belt tool (pump and flywheel pin)
  11. Fuel filter (Rovers North ProLine OK?)
  12. Air filter (Rovers North ProLine OK?)
  13. Grease or 75W-90 for swivel balls
  14. Grease 6 driveshaft zerk fittings
  15. Valve cover gasket (check valve clearance .2mm)
Old May 16th, 2016, 05:23 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Number 13. Land Rover has a special swivel lube. The 75W-90 was specified for early Defenders but I think the consensus here is to use the special swivel lube.
There is a third party swivel lube (Britpart? Not sure) and I believe the consensus here is it's Okay and preferred to 75W-90.
Do you know how many miles are on the timing belt? Or do you not know or not trust the reported miles?
You will have fun! Pictures when you can.
Old May 16th, 2016, 06:16 PM
Naplm00
Matthew
Agreed with above, I'd do a timing belt, tensioner, waterpump, cam and crank seals while you are I there.
All other fluids look fine except I wouldn't use syn in the diffs just regular gear oil seems to work fine for me but ymmv.
Aftermarket oil filter ph8a will also work but the capacity is a bit smaller then stock.
A 3/8 or.drill bit will work for the timing belt pump pin instead of the oem tool. You will also need a 3/8 click type and a 3/8 torque bar style torque wrenches to do the timing belt correctly.
You will need arp thread sealant or similar for the waterpump bolts and rtv silicone.
I use britpart/all makes for everything except for brake, timing and seals.
Trevor @ rovahfarm will have better prices than rn and is easy to deal with he has oem and aftermarket parts.
Lt77 filter is cleanable and does not have to be replaced
Use 5 year coolant (not dexcool) and an additive for diesel engines to keep water jacket rust at bay.
Since you are in NY, I'd also think about adding a block heater if you plan to drive during the winter.
Edit: an oil syringe or pump makes adding oil to the diffs and cases much easier.
http://www.amazon.com/Plews-55001-Lu.../dp/B000BQW5LK
Old May 16th, 2016, 07:20 PM
AdamSanta85
91' D90 200TDI
Cool thanks for the helpful advice. I didn't know about the diesel additive. I will also add the cam and crank seals to the list. I didn't know about Rovah Farm.
------ Follow up post added May 16th, 2016 07:21 PM ------
Thanks. I see this swivel lube. I will grab it.
Not sure how many miles on the timing belt, better safe then sorry.
Trek Challenge Truck Photos- 2003 Truck aosias Misc. Chit-Chat 6 April 26th, 2010 06:23 AM
Rooster Ron's new truck logo... pmd Misc. Chit-Chat 24 March 1st, 2008 07:54 AM
Finally got the new truck together (Pics) shawnpalmer Misc. Chit-Chat 9 April 17th, 2007 12:55 PM
New truck product--BRAVO Davis Misc. Chit-Chat 17 October 10th, 2006 10:50 PM
Question about D90 maintence repstein Defender Technical Discussions 8 June 17th, 2004 11:54 AM
