Main Light Switch / Headlights Issue - Defender Source
Old January 13th, 2015, 11:25 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
All of a sudden, my headlights won't go on when the main switch is in position 2. In position 1, all the parking lights, dash lights, etc. all come on as usual.
But when I switch to position 2, dash lights go off, no headlights, no parking lights.
opened the steering column nacelle, tested switch and it's ok
shorted the contacts to switch the lights on - position 1 ok, position 2 has no effect
swapped in another relay for the headlight relay, nothing
checked fuses - all ok
checked the fusible links in the engine bay - all ok
Is there something else I'm missing guys? thanks as always.
Old January 13th, 2015, 11:42 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
dip / dim switch in the turn signal stalk is burnt out.
Firemanshort
1980 Stage One 109
Sterling, VA
Old January 13th, 2015, 11:47 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Unfortunately very common. But is it the high beam/dip switch in the turn stalk, or the light switch (seen this many times, as opposed to the dip switch). When you replace it, it is HIGHLY recommended that you also install a headlamp wiring harness, that takes the load off the switch, and puts it on a the larger gauge wiring and relays of the harness (relegating your stalk switch to the load of clicking the relays on and off)..
http://www.defendersource.com/faq/Light/LightHead.html
http://www.defendersource.com/forum/...ad.php?t=14715
~Scott T.
'95 D-90 ST - AA Yellow
Old January 13th, 2015, 12:11 PM
rankar's Avatar
rankar
I thought about this as a possibility. thanks.
------ Follow up post added January 13th, 2015 12:12 PM ------
Thanks Scott. Extremely helpful. I was doing some searching but just didn't turn this up. I appreciate the source too for the harness.
Old January 14th, 2015, 04:54 PM
rankar's Avatar
rankar
any other suggestions guys?
I changed out the turn signal/horn/dip stalk, and same thing - parking lights and dash come on when main light switch is in the number 1 position. but switching it to the number 2 position turns off dash lights and no headlights.
Flashing (high beams) on the turn stalk works, just as with the old turning stalk.
Any other suggestions I should try?
Old January 14th, 2015, 04:58 PM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
Had a similar situation in my RRC, root cause turned out to be a bad common ground.
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old January 14th, 2015, 05:39 PM
rankar's Avatar
rankar
I bet it's the main light switch. I'm going to do a test...
Old January 14th, 2015, 05:42 PM
I had this exact same thing happen to me on the way to work the other morning, and it was the switch. If you take apart the switch you can see where it hits the contacts. The contact had completely fallen out of the switch (probably melted the plastic). I had a spare switch I put it, but was also able to repair the original to keep as a spare.
Old January 14th, 2015, 05:53 PM
defender1844
Amit Likhyani
glad I saw this. My high beams no longer work. I'll check the switch and upgrade to a relay once I determine that's the problem.
Old January 14th, 2015, 06:48 PM
Yours probably isn't the main headlamp switch.
Old January 14th, 2015, 07:07 PM
rankar's Avatar
rankar
Amit, I don't think your problem is the main light switch either.
My problem was the main light switch all along.
When I initially took off the connector, I made the mistake of assuming the 3-conductor main switch was an SPDT switch. This was not the case when I re-read the electrical library book. In the book, it says, "...position 2 additionally switches on the headlights." So "additionally" was the clue that this was not an SPDT switch.
Instead, the switch flows power from position 1 to position 2 ALSO, off of the brown wire. So upon re-testing, there was no continuity on the switch from brown to position 2. And to confirm, I pulled back the wire sheathing on the switch, shorted the contacts on brown to position 1, then from position 1 to 2 and bingo - headlights on.
So have to order a new main light switch, then install that and the ARB relay setup.
I swear, when I get to tearing down my 90, I'm wiring in solid-state relays and wiring up my own harnesses, my own bus systems, etc. etc.
ht, lights, switch
300Tdi intermittent start issue - starter or main chassis ground? nathanwind Defender Technical Discussions 30 February 21st, 2015 10:04 PM
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Aux. light switch (RRC headlight switch) $40 shipped evilfij For Sale - Parts 0 September 5th, 2008 05:12 PM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
