Main light switch - Defender Source
Old November 13th, 2005, 07:34 PM
jchan88
james chan
1997 Defender 90 ST white
Main light switch
Newbie question here,
I have a 97 d-90 ST and my main light switch went haywire...I just removed and reinstalled new light switch. My question is that when you 'flip' the light switch WITHOUT the keys in the ignition are the headlights supposed to turn on as well without the keys in the ignition? Right now, the only way that the headlights turn on is when the car is started? Is this correct? because my other vehicles can turn on the headlights w/out the keys in the ignition (acc position). Thanks in advance
Old November 13th, 2005, 07:43 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
with the key in the off position only the side lights (running lights) will illuminate - lots of european cars do this.
Old November 13th, 2005, 09:01 PM
Yep it's right!
Old November 13th, 2005, 09:43 PM
jchan88
james chan
thanks guys.....
ht, switch
little plastic thin piece that is glued down to cover the light near the heat switch d90guyinla Wanted 10 February 5th, 2013 05:01 PM
Head light switch repair - Is this 4 real? paulb Defender Technical Discussions 11 March 17th, 2010 02:53 PM
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Light switch! TwisteD90 Defender Technical Discussions 6 February 3rd, 2004 04:07 PM
