Main headlights switch - Defender Source
Old October 19th, 2015, 06:09 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
My main beam headlight stalk switch is playing up. It only turns the main beams on if I push it forward beyond its normal position. The contacts seem to have gone inside at at the normal on position, but it works if I push it further in that direction.
Is this something I can fix by removing the switch or is replacement the solution?
Cheers,
Old October 19th, 2015, 06:26 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
To tell you truth get a new switch and also get a headlight relay harness fitted, the harness is the next best thing to LEDs.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old October 19th, 2015, 08:49 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
Cheers,
Yup this is common issue - especially if you have upgraded lights like H4s. do some searches and you'll find a lot on this topic. OEM switches burned out on me twice and I replaced it with a toggle from the local hardware store that was a temporary fix that has lasted many many many years. A relay is on my "to do" list, but my toggle works
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old October 19th, 2015, 09:16 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
There is a ball bearing inside the switch mechanism, over time it wears down the ridges that give that click sound when you move the stalk. Like any other electrical item, genuine ($$$$) will hold up better but that stalk switch will always wear out no matter what. Its easy'ish to replace, way easier if you remove the steering wheel to get to the stalk fasteners(?). Think my Pops truck is on its third headlight stalk now.
Main Light Switch / Headlights Issue rankar Defender Technical Discussions 10 January 14th, 2015 07:07 PM
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Aux. light switch (RRC headlight switch) $40 shipped evilfij For Sale - Parts 0 September 5th, 2008 05:12 PM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
