Main gear Lever gone vague - bias spring? - Defender Source
Old March 18th, 2012, 02:07 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I've searched but can't find anything relevant.
Trouble is:- Discovery LT77 main gear lever has gone all "floppy". Instead of resting at the 3rd 4th gate in the neutral position it now falls all the way over in 5th gear position. There's still resistance to going into reverse from a spring but no guidance at all for selecting 3rd and 4th. She who must be obeyed hates this with a passion. I think the bias spring is the culprit. Is this located in the gear selector housing?
Anyone out there know if this can be accessed without having to drop the transmission.
We're talking Discovery 1 here.
If it was the 110 I'd pull the floor and have a look.
Can it be accessed as easily on a Discovery?
Mike Hammond
Old March 18th, 2012, 02:25 PM
On a disco you have to pull the center console out and undo the tunnel cover. It's a fiddly all-day job. There is a tension spring (FRC7414) that may have gone the way of the mastodon.
Old March 18th, 2012, 02:28 PM
mikeslandrover
Mike Hammond
Thanks for that. Fiddly and all day two words that go together when working on a 20 year old discovery
There's a whole lot of sill welding in the not too distant future too.
------ Follow up post added March 18th, 2012 06:34 PM ------
FRC7414 is that the same part for a discovery box?
Mike Hammond
Old March 18th, 2012, 02:56 PM
Probably. I got that from the 110 parts book. Just do a search on it at Paddocks or Craddocks or any other ducks you prefer.
Old March 18th, 2012, 03:02 PM
mikeslandrover
Mike Hammond
O.K. been doing that comes up blank, think there must be different bits in there, more complicated.
Anyone got a parts diagram for a discovery?
Mike Hammond
Old March 18th, 2012, 04:18 PM
Try the numcat page. I found this
Old March 18th, 2012, 04:32 PM
Actually, sounds like you are talking about the "real" series 1 Disco....200TDI era. Opening the center console is easy. Maybe 30 minutes (yes, I have personally done this job). It is all obvious once you are in there. Read the workshop manual as it is well explained. The reverse spring is separate from the main spring. I would first assume the bias spring plate has come loose.
Old March 18th, 2012, 04:52 PM
mikeslandrover
Mike Hammond
That is just the sort of thing I need, Brilliant Thanks
Mike Hammond
Old March 18th, 2012, 05:33 PM
mikeslandrover
Mike Hammond
Thanks, with your advice & the diagrams I think I'm sorted, just got to dive in and fix it, parts aren't pricey for a change hopefully pick them up tomorrow or via the web.
Brill thanks for the help
I'll post some pics when I tear into it.
Mike Hammond
Old March 19th, 2012, 03:02 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
It could just be the grub screw on the bottom of the gearstick....(take the casing off that the stick it attached to, and you'll see the top of the selector rod thing, don't know its proper name, and the "cup" that the "ball" of the gearstick. the "cup" is what is held in place with te grub screw)
can you still select gears? if not, then more likely the grub screw come loose (5 or 6mm i think, lock it up with some locktite)
If you can select gears but the stick is all floppy, then one of the springs is prolly broken.
Old March 19th, 2012, 01:38 PM
mikeslandrover
Mike Hammond
Hi Jim,
It's the latter of the two cases, I'm just about to order the two springs and the base plate, they're not expensive and it sounds like it' a bit of a task to get in past all the trim & sound deadening. Why can't my good lady wife drive a proper Land Rover, it'd be a 1/2 hour job.
Mike Hammond
Old March 24th, 2012, 06:22 PM
mikeslandrover
Mike Hammond
Splendid, Mended
3 hour job including welding the hand brake base plate the had snapped in half. There's always a catalog of woes when I start any work on the discovery. Still at least it was a sitting down job & my 6 year old helped in a useful fashion.
ID:	49459   Click image for larger version
ID:	49461   Click image for larger version
ID:	49463   Click image for larger version
Mike Hammond
WTS: 110 fuel sending unit, Terrafirma spring retainers, Land Rover Gear Sandals mcoleman762 For Sale - Parts 4 October 6th, 2011 09:13 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
