M416 trailer questions - Defender Source
Old June 27th, 2012, 09:21 AM
USLandy's Avatar
USLandy
Andrew
defender 90
So I'm looking to build my own trailer, replicating the m416. The only old trailers I have found are going for about 1200 bucks and are all rusty and old so I figured I have a welder, I'm going to build my own, but I have a few questions for people who own/rebuilt them.
1)I was looking for the axle dimensions on the web and know the spring center to center distance is 39" but couldn't find the hub to hub dimension, anyone got this?? I'm planning on getting Dexter 3500lb axles with electric brakes. (some of the custom build ones don't look like they even have brakes....)
2) I plan on including the following in my build: roof top tent, built in water tank, pull out table, mnt. bike mounts, drain spout, jerry can mounts. Other than these do people have any thoughts on what to add from their experiences, what worked best for them or what didnt work well???
Right now I'm doing the design work, I'll have some plans all finished shortly, I hope...
thanks in advance
Old June 27th, 2012, 09:28 AM
You so need to go over to Expo portal for this. That's one of that forum's core competences.
Old June 27th, 2012, 09:35 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I believe you will be looking for an axle with a 70-72" hub to hub dimension but you will have a hard time if you are trying to match the Rover wheel pattern (unless you have adapters made). However, like Overlander said, Expo is a much better place to check out. There are literally hundreds (if not thousands) of threads from folks doing exactly what you plan to do.
Old June 27th, 2012, 09:58 AM
USLandy's Avatar
USLandy
Andrew
defender 90
I had seen a few websites more tailored towards the trailers but this is a new one, I will be checking that out.
I was planning on getting the axle in a 5 on 5 and then fitting adapters for the 5 on 6.5 to fit landy wheels.
Thanks for the quick responses. Once I get some things drawn up ill try post them up on here
Old June 27th, 2012, 04:42 PM
Howsomever
Wayne Phelps
1984 D110
I bought an M416 trailer many years ago. Cut off the original spindles which were part of the continuous axle and welded on a flange that was machined to accept the standard series Rover spindle. This allowed me to use Series Rover hubs and wheels. All this was done so the width was the same as the Series Rover. These trailers were designed to carry 500 pounds but I lost track of the number of times I hauled a cubic yard of 3/4 minus. This was a sweet setup and I would never sell mine as long as I have the Rover. Much lighter than a Sankey. I would still consider the M416.......it won't go down in price
Old June 27th, 2012, 07:10 PM
I've had a m416 for years. Great trailer loaded up a yard plus of soil mulch etc without complaint.
It's stock except for hub adapters from 5.5 to 4.5. Good for jeep wheels but they tend to stick out. Running 235/70-16 tires right now.
Yes it's a little smaller than a wide body Sankey but that hadn't been a problem yet.
One feature I really like is the E brake and I'd hate to lose that
Old June 27th, 2012, 07:43 PM
87 D110 (Ruby)
Same post you posted up in the other forum...same answers. Go to EXPO
Old June 28th, 2012, 09:37 AM
USLandy's Avatar
USLandy
Andrew
defender 90
Thanks everyone, yea expo is a great resource with this topic. I'm surprised I had never found it before... Spent a few hours on there looking at what else I want to integrate into my design and I started throwing the main stuff on to a CAD program so I can make sure everything fits!
Not all to sure where I already posted this though 1971series88, I know sometimes my brain goes into autopilot but I cannot remember posting this twice.
Old June 28th, 2012, 10:20 AM
usadventureracing's Avatar
usadventureracing
Brett
110
I notice you are in "Chicago", I am not far from you and have a M416. If you need any measurements just let me know.
Brett
1983 ROW D110
1970 Series III (Parting out)
Old June 29th, 2012, 09:03 AM
USLandy's Avatar
USLandy
Andrew
defender 90
Thanks for the offer USADVENTURE, if I get stuck I may shoot you a PM and organize a time to take a look, I'm up in Deerfield, well I'm between there and valpo Indiana.
Old June 30th, 2012, 03:11 PM
Also look at the yahoo groups m416 forum
Old June 30th, 2012, 03:15 PM
usadventureracing
Brett
110
Anytime, I am in Crystal Lake.
1983 ROW D110
Old June 30th, 2012, 04:15 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Look at the Canadian m101a yahoo group, I remember a cad drawing posted there and dimensions.
M101a was kind of an updated improved version of the 416 and you can still good rust free ones.
Old August 19th, 2012, 03:36 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
USLandy, did you ever find 5-6.5" adaptors for your project?
I found a sweet M416 at an estate sale, happened to spot it under a pile of old wood, made an offer an stole it. Couldn't get it out fast enough, even had the cheek to ask for a bill of sale.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old August 19th, 2012, 05:21 PM
roverman2010
1985 LR 90 200Tdi
You arent allowed to do a post like that without pics at the very least, but you really need to start a threat in the projects section.
-Jeff
I was doing a follow up on USLandy's post as I didn't start the THREAD. As I did a search on this subject I didn't look to see what section it was in.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
FS trailer M416 roverx For Sale - Vehicles 2 June 22nd, 2011 08:35 AM
M416 Trailer with ARB Simpson RTT Rugbier For Sale - Parts 2 May 7th, 2011 04:04 PM
M416 trailer roverx For Sale - Parts 2 April 17th, 2011 08:10 AM
M101 - A3 Dump Trailer - $2000 (Salt Lake City) themaxx The Flea Market 5 March 19th, 2010 07:49 AM
M416 trailer galen216 For Sale - Parts 6 September 24th, 2009 08:58 AM
