M&D Eng UK 2.8 TDi VNT Engine experiences - Defender Source
Old July 26th, 2016, 04:16 PM
fraser61's Avatar
fraser61
Fraser Gourlay
1986 D110 TUM 300Tdi
Afternoon Everyone
I'm looking at one of these engines to power my LHD Tithonus. Does anyone have any experience with this Company Motor and Diesel Engineering UK and/or their engines which are purported to be very similar to the MWM International 2.8 HS engines, the Brazilian subsidiary of Navistar International.
Thanks in advance for any insights
Cheers
Fras61
2008 RRS SC
1986 D110 Tithonus 300TDi RHD
1979 S3 Lightweight
2006 ZX-10R
Beauty is in the eye of the beholder, get it out with eye drops.
Old July 26th, 2016, 04:26 PM
Several of us on the board have that engine. M&D is the primary supplier and SME of that engine in the Western English speaking world.
While the engine is undoubtedly more powerful than the 300 TDI, as well as supposedly some better engineering improvements to make it more reliable than the 300 TDI, I have personally had some unfortunate setbacks early on with mine that lead me ultimately to an early full rebuild by Safari HP only recently completed.
The engine shares many components with the 300 TDI, but not all, and those differences are poorly documented. I started a thread a while back on 2.8 TGV parts compatibility for a place to documents those commonalities.
If you have one installed, make sure it's timed correctly on installation. Don't assume it was done correctly from the factory. I have a cracked head in my first 30k miles. Also make sure you have a knowledgeable Rover diesel mechanic identified (that is credible) before committing. There are enough nuances between the 2.8 and 300tdi, to let an unexperienced mechanic following the LR 300 TDI manual to get you into trouble.
From a parts availability side, I also posted a link on a Brazilian supplier, that can supply 2.8 parts around the same cost as 300 TDI parts. Majority of parts from M&D will end up double the cost of 300 TDI parts.
Mark Kellgren
KM4BOR
M&D sells the International engines. They have not been in production for a few years now, so I don't think they have new ones.
Old July 26th, 2016, 04:31 PM
fraser61's Avatar
fraser61
Fraser Gourlay
Mark
Can you please go into a little more detail about the setbacks experienced as I'm not a professional mechanic and I don't really know anyone in the Houston Area that is trained on 300TDis, so this would be of great interest, if these were preventable issues.
Thanks in advance
Fraser
Fras61
2008 RRS SC
1979 S3 Lightweight
2006 ZX-10R
if you order a complete engine from them now, they actually build one from parts using a 300 TDI block and their 2.8 conversion kit (with correct sized pistons, etc) and it requires a month lead time. It's not a pure 2.8.
Mark Kellgren
KM4BOR
Old July 26th, 2016, 05:45 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Originally Posted by fraser61 View Post
Mark Can you please go into a little more detail about the setbacks experienced as I'm not a professional mechanic and I don't really know anyone in the Houston Area that is trained on 300TDis, so this would be of great interest, if these were preventable issues. Thanks in advance Fraser
I've been told there is an indie LR shop in Spring, TX that is familiar with the 300Tdi. Don't know if they are knowledgeable on the 2.8.
I had a number of issues with my 2.8 that forced me to regret the conversion. But Pendy has promised that I will be very happy with it when he is finished with rebuilding it.
Black Rhino Lives Matter
Old July 26th, 2016, 06:03 PM
fraser61's Avatar
fraser61
Fraser Gourlay
Luis
Same question then, what were the issues, please share, that was my whole purpose for asking this question.
Thanks in advance
Fraser
Fras61
2008 RRS SC
1979 S3 Lightweight
2006 ZX-10R
Old July 26th, 2016, 06:26 PM
Reading M&d site, looks like they are taking 300tdi's and rebuilding them into 2.8 litre engines. That could well be the solution to the International's problems, plus parts availability to!
Old July 26th, 2016, 10:04 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
No info related to the 2.8 or 300tdi;however, I use M&D regularly for parts on the mama sl35ti. They are a top notch business. Call, ask for parts, give CC info, get parts quickly. They aren't a clown show.
You little rebel, I like you.
Old July 27th, 2016, 07:52 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I've been using my 2.8 for 11 years now with around 50K miles. Have only had minor maintenance, and recently did the headgasket due to age. No major issues. I have noticed that historically, this engine really, really does not like being overheated (reading through the history of issues on them). Putting it in a 110, I would focus on the cooling extensively.
Old July 27th, 2016, 08:03 AM
Going further, I recommend to anyone considering that a 4 core radiator is mandatory. These generate quite a bit more heat, and summer days in lower latitudes on the highway will creep up from heat soak on a stock 3 core.
Mark Kellgren
KM4BOR
Old July 28th, 2016, 10:23 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have installed one with no issues. Also Did an allisport custom Aluminum Rad to help with cooling.
Legend in My Own Mind.
Old July 31st, 2016, 12:59 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Hi Fraser,
I ordered my 2.8TgV in 2005 from M&D. Put it in in my driveway. It
bolted right up to the R380 and used the same engine mounts as the V8.
So far I have 75K miles and the only issues I've had is a clogged fuel filter
(cause I was a diesel newbie) and the bearing went out on the belt tensioner.
I've been very happy with it. Tons of torque and will run 70mph all day on the highway.
I ordered the HD radiator when I got it and have had no overheating problems.
With all this being said, your mileage my vary. I've read other people on here that
have had problems but my experience has only been positive.
Good luck.
Bryan
Old July 31st, 2016, 06:01 PM
also note that M&D does use some Britparts for their kit. My fuel filter housing failed within the first year of install, leaving me stranded at work. I would recommend going genuine or performance aftermarket for components that will disable you. i installed a heated racor, and very happy.
Safari also told me they have had numerous vibration issues with the Britpart engine mounts provided in the M&D kit. they replaced with genuine to resolve in all cases.
Mark Kellgren
KM4BOR
Old July 31st, 2016, 06:26 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Will that be at the end of Trump's second term??
Sorry...
Rent my
Old July 31st, 2016, 07:56 PM
Michael
Michael
Discovery 1998
I have the International MWM HS2.8L M&D Kit on my Disco with Autobox.
I, too, first installed it my self back in 2005.
Incredible engine, and by coincidence, I am selling one.
Old July 31st, 2016, 10:56 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Will that be at the end of Trump's second term?? Sorry... .
You know something? You are right he has had it since before Obama took office. 😖
Old July 31st, 2016, 11:15 PM
SGS714's Avatar
SGS714
Scott Striglos
3xRRC 2xD90 2xD110 Series II, IIA
I bought one from Safari and they did the install about 6 months ago. Very happy with the engine.
Thank you,
67 Series II
71 Series IIa 88" ACR 2.8 Power Plus
89 RRC 2 door VM 2.5TD
93 D110 NAS #327
94 2x D90 NAS #'s 1076 ACR 4.8, 1161 SBC
94 D90 NAS now a D110 HS 2.8 aka Project Wolf
95 2x RRC
1-SWB,Doing the LS Gen IV 98% Done
1-LWB 300tdi
Old August 1st, 2016, 12:00 AM
Brigante's Avatar
Brigante
Art V
D-90 1995
Originally Posted by Michael View Post
I have the International MWM HS2.8L M&D Kit on my Disco with Autobox. I, too, first installed it my self back in 2005. Incredible engine, and by coincidence, I am selling one.
How much are you selling the one you have?
Old August 1st, 2016, 07:35 AM
Michael
Michael
Discovery 1998
Asking $8800 for the Kit. would it be for the d-90 ?
Asking $9800 for the whole truck which has some very nice HD parts including old-school Kam-diff lever operated rear locker.
see For Sale - Vehicles and For Sale - Parts
engine, tdi
M&D Engineering VNT Turbo Kit chris snell For Sale - Parts 27 February 17th, 2015 11:38 PM
Turbo boost, International 2.8L engine with VNT Santiago Defender Technical Discussions 27 January 13th, 2014 04:01 PM
300 TDI VNT Turbo Kit For Sale Oliver Whiting For Sale - Parts 4 August 5th, 2013 10:43 AM
Experiences with Off-Road Trailers? LRNAD90 Defender Technical Discussions 11 August 9th, 2008 11:54 PM
Diesel Conversion Experiences JimC Defender Technical Discussions 10 December 13th, 2004 05:22 PM
