Lurchy clutch - Defender Source
Old December 17th, 2003, 05:42 PM
Seanh
Sean Hanagan
94 D90 ST #910 Matilda
Question Lurchy clutch
I've noticed some lurching in the clutch in both reverse and 1st gear and I was wondering if this was indicative of anything specific. Thanks in advance,
Sean
BTW: 60k on current clutch w/ r380
Old December 17th, 2003, 05:51 PM
lobster's Avatar
lobster
Rob Goodall
1995 D90
I have found it easier to push the clutch in lately. Any help would be appreciated. Sorry to jump in on your thread
1995 D90 ST
1999 Super V8
Old December 17th, 2003, 09:18 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
Sean - my truck was doing the same thing a while back but only when it had been parked overnight. for me the fix was replacing the slave cylinder because it was leaking. the general rule as I understand (correct me if I'm wrong) is to replace the clutch MC, flex hose, and SC at the same time.
Rob - check your clutch fluid level. top off and bleed if real low. as always check for leaks.
Insert pithy quote here.
Old December 17th, 2003, 11:18 PM
I don't think you have to replace them all at once, but if it has high mileage and since you are in there. My MC died earlier this year. I replaced it, it is hard to get in and out and it takes a while to bleed it. If you are leaking check to see if any is getting onto the clutch peddle, if so then it is probably the MC. When my fluid got low the peddle was real soft, if it got too low it would not work and I would have to refill it and bleed it.
Old December 18th, 2003, 11:30 AM
lobster's Avatar
lobster
Rob Goodall
1995 D90
I checked the fluid and it was full.
clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
