Lumenition conversion - no spark from coil? - Defender Source
Old April 12th, 2016, 01:53 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Trying to solve a no start situation & when I opened up the access panel thru the top of the fender above my coil, I noticed that it was wired into what turns out to be a " Lumenition " electronic ignition conversion, which is made available for Series & D's thru 1985. Fwiw, the outward appearance of it suggests that it is the "standard" version. Here's the mfr's product description page: Optronic product guide - AUTOCAR
Anyway, I'm in the "no start" situation - when I turn on the ignition key, I've got spark coming into the positive terminal of the coil, but I can't get either the old coil or a new cross-referenced coil from NAPA to show me any spark coming out of the thick wire that comes out of the coil & plugs into the top of the distributor cap amongst all the incoming spark plug wires...
So, on this type of modified ignition, should I even be concerned about finding spark on that wire? - does it modify/bypass the setup to an extent that there should NEVER be any spark in that particular wire???
And why no love here for the Lumenition? - not even a single search result here for that word & no Google results for U.S. retailers - is this something that I should consider removing?
coil, conversion
Coil Immobilizer - Genuine Land Rover Part AMR4897 - COIL ENGINE IMMOBILIZER Ben01 For Sale - Parts 1 January 17th, 2016 05:40 PM
73 Land Rover Series 3 diesel coil conversion seen on the IH8MUD forum ADK46er The Flea Market 3 October 18th, 2011 01:09 AM
Good Spark, Bad Spark Big D Defender Technical Discussions 4 August 19th, 2008 09:43 AM
Wanted- Defender or coil spring 110/109 for Series 109 conversion Rovermn Wanted 1 August 4th, 2008 06:04 AM
Any other Series Coil conversion owners? KevinNY Misc. Chit-Chat 2 December 13th, 2005 09:00 AM
