Lug Nuts!!! Get loose today !!!! - Defender Source
Old October 22nd, 2004, 12:26 AM
Vadim
vadim
95 D90
Question Lug Nuts!!! Get loose today !!!!
Hi everybody.When I was driving today,I was feeling something wrong with truck.Was some knocking in front end , and I got feelings I will roll over truck on every corner I drove.I stop on look under truck ..none.My friend look on my rims ,and point to lug nuts !!! They all was loose ,I can turn them by hand !!!! It's is usally for lug nuts get loose ? I never see anything like that before! Should I check them more often ?
Thank you
Vadim
Old October 22nd, 2004, 01:09 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Seen it happen before, did you have the tires off recently? Let me guess, drivers side?
I've found that not only the torque sequence is important, but also where on the jack the truck is makes a difference too. I usually snug down when it's still on the jack to seat the lugs. Then I lower the jack just enough to prevent the tire from turning but not put much weight on the tire and torque fully. Then I totally drop the truck off the jack and torque again twice.
Also, make sure to use a good wheel spider, and not the wimpy lug wrench that came with the truck. The factory lug wrench doesn't get enough leverage normally, and won't tighten the nuts enough.
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 22nd, 2004, 01:14 AM
Vadim
vadim
95 D90
Actually both front tires was loose!! And I can't even remember when I took my tires off!! Men ,I was shock ,when its happen!!
Thank you
Vadim
Old October 22nd, 2004, 11:47 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Have you tried tightening them?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 22nd, 2004, 03:01 PM
Vadim
vadim
95 D90
Yes I did last night,now I will watch them period
Old October 23rd, 2004, 06:19 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
and when you tightened them the last time, did you use a torque wrench? One should always be used, except in emergency roadside repair situations.
I haul dual-axle RV and livestock trailers with my (non-Rover) pickup. Makers of these trailers are always cautionig that the lug nuts must be checked regularly, as tight turns put alot of stress on the wheels and tend to work the nuts loose over time.
If you're running big tires on the '90, maybe you're putting the same kind of stress on the wheels.
Old October 23rd, 2004, 12:26 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
My driver's rear tire came loose recently--I was totally shocked. I am pretty anal about tightening my wheels, so this was a bit of a surprise. I am always fussing with the truck and did have the wheels off, but when the rims go on, they get tightened. I am a bit of a conspiracy guy, so I am guessing it was SABOTAGE! O.K., probably not but sure make me feel better thinking I did not do anything wrong...in other words, it does happen and you are not alone
Old October 25th, 2004, 01:51 AM
Vadim
vadim
95 D90
I thought same way SABOTAGE! But I don't have any problems with any body )I think it's just happen)
Old October 26th, 2004, 02:18 AM
whistler110's Avatar
whistler110
Mike Johnstone
ex-mod 110
Buy a compressor and an impact gun, problem solved.
When I got my truck, I couldn't take the lug nuts off so I went to a tire shop and had them do it. I was fitting new tires anyway. They said that the torque they were at was correct for that size of lug, so I went out and bought a 4ft bar and lug wrench and haven't had any problems since. If you can remove the lugs with a normal sized lug wrench it probably isn't tight enough.
Knock on wood, I'm checking them tommorow.
Bike Mike
Old October 26th, 2004, 03:21 AM
Vadim
vadim
95 D90
I have compressor,but I never suspect it may happen,but now I do)
Old October 26th, 2004, 03:58 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
Like i said, use a torque wrench to make sure you're putting them on tight enough. The nuts are quite a bit bigger than other cars, and 100 ft-lbs. may be difficult for some people.
I've had trouble taking the nuts off with the factory lug wrench. Last time I tried, I just ended up twisting the wrench. Ended up going to Sears and replacing it with a proper metric socket and a 2 ft. breaker bar. When I stand my 200+ pounds on the end of that thing, there's no problem getting the nuts off.
Stupid Question.....about lug nuts excanuk Defender Technical Discussions 31 July 22nd, 2008 06:38 PM
lug nuts NashvilleRedD90 Wanted 4 November 3rd, 2005 03:37 PM
Stock wheels and lug nuts! TwisteD90 For Sale - Parts 3 February 1st, 2005 04:24 PM
Disco II Lug Nuts javelinadave For Sale - Parts 0 January 21st, 2005 11:55 PM
more lug nuts erik d For Sale - Parts 0 January 1st, 2005 12:27 PM
