Lug Nuts don't fit?! - Defender Source
Old May 25th, 2007, 03:29 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I removed the steel wheels from my 110 to send out to be sandblasted and powdercoated and was going to leave the truck on a set of tornados I had layin' around. I know that you have to have the alloy lug nuts but the alloy lug nuts are a different thread size than the 110 studs. I thought someone had told me that all you had to do was to use the right lug nuts and a spacer if you want to be able to run the center caps. Do you have to swap studs too or are there two different thread size alloy lug nuts available?
Thanks in advance guys!
Old May 25th, 2007, 04:56 PM
There two different thread size alloy lug nuts available... The RR, D1 and Defenders have a larger Stud, but the D2 and P38 RR are slightly smaller. I had an old set of lug nuts from my RR 4.6, that I wanted to put on my 90, but they would not work.
Stupid Question.....about lug nuts excanuk Defender Technical Discussions 31 July 22nd, 2008 06:38 PM
Steel Wheel Lug Nuts woldd90 Wanted 1 November 19th, 2005 07:44 PM
lug nuts NashvilleRedD90 Wanted 4 November 3rd, 2005 03:37 PM
Disco II Lug Nuts javelinadave For Sale - Parts 0 January 21st, 2005 11:55 PM
Lug Nuts!!! Get loose today !!!! Vadim Defender Technical Discussions 10 October 26th, 2004 03:58 AM
