Lug Nut question: quick and easy - Defender Source
Old March 28th, 2010, 02:04 PM
fenwaystan's Avatar
fenwaystan
Christopher Giles
1997 D-90
I have researched the threads on the site and I must say, I am still a bit confused. I want to buy a breaker bar and the proper socket. I understand I need a 27mm socket for stock Land Rover alloy rims. True? Deep or standard depth better?
Here is where it seems off. There are indeed "caps" on my lug nuts that feel thin and loose e.g. the move a little on each of the lug nuts. Do they come off before using a wrench or are they strong enough to put a socket on?
Thanks everyone.
Old March 28th, 2010, 02:27 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
for both steel and alloy LR wheels use 1 1/16"
I have/owned both
any larger and you will round the corners
keep the caps on, they do/should not come off
deep or standard socket is fine
torque to 100ft lbs
I like the one from RN---> Lug Wrench
I also put anti-seize on the lug threads
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old March 28th, 2010, 11:17 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Jon is right, 1 1/16" fits perfect (same as 27mm) and it
will be cheaper than a metric socket. Get a 6 points
socket and a long breaker bar. I recently got a 17"
long breaker bar for around $12 on amazon.
- Charles Eames
Old March 29th, 2010, 08:19 AM
fenwaystan's Avatar
fenwaystan
Christopher Giles
1997 D-90
Thanks Jon & Julien, I will grab a 1 1/16" socket and breaker bar. Fastenal (just up the street) was a fortune so I'm off to the internet.
Old March 29th, 2010, 11:14 AM
Personally, I would also grab a 1 1/8th 6 point socket too. Sometimes the caps on the lugnuts swell and you can't get a 27mm or 1 1/16th on there.
Old May 9th, 2010, 07:00 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Stupid newbie question, but will a 12 point deep 27mm socket not fit on the lugs?
Old May 9th, 2010, 07:07 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
It will work, however 12pt sockets have a tendency to round corners.
Ron, a 1 1/16" will always work. YOU just need a bigger hammer.
What tree?
Old May 9th, 2010, 10:20 PM
27mm socket and a breaker bar, Ive broken every Land Rover lug wrench I touched.
WARN Booster/Jumper Cable Quick Connect Kit pcscharfe For Sale - Parts 8 June 13th, 2009 01:23 PM
Draining Oil Made Easy Davis Defender Technical Discussions 14 March 5th, 2004 01:38 PM
