Lug Nut Question - Defender Source
Old March 18th, 2015, 12:00 AM
89Defender90
none
none
Registered User
Lug Nut Question
While I was replacing the wheels, I noticed two different lugs on my truck. Why do the Chrome capped lugs have a tapered base and the plain metal lugs have a flat base?
ID:	116301   Click image for larger version
Old March 18th, 2015, 12:08 AM
89Defender90
none
none
Registered User
I did search, but saw listings for both lugs used for aluminum wheels....just wanted clarification.
Just wanted to make sure the capped nuts are okay for aluminum wheels. Both will seat the wheel with the washer and the taper doesn't make it through the lug hole on the wheel.
lug nut question wilyliang Defender Technical Discussions 8 February 25th, 2012 05:14 PM
lug nut question sirjond Defender Technical Discussions 14 July 15th, 2010 01:40 PM
Lug Nut question: quick and easy fenwaystan Defender Technical Discussions 7 May 9th, 2010 10:20 PM
Lug Nut Question floyd650 Defender Technical Discussions 10 December 18th, 2009 05:14 PM
Winch Bolt/Nut locks - like wheel(lug nut) locks Jase Defender Technical Discussions 4 February 20th, 2005 08:31 PM
