Lube seat rails - How? - Defender Source
Old January 24th, 2015, 08:38 PM
doscazadores
Vic Stull
none
Driver's seat on my '95 D90 will hardly budge. Nothing in owner's manual or the D90 shop manual found that helps. So how can I fix this problem? (Need to move the seat ALL the way forward so my wife can learn how to drive it should the need arise.) Looked it over and I don't see an obvious solution.
Thanks for any help.
Vic
Old January 24th, 2015, 09:01 PM
cascade90's Avatar
cascade90
Mason Worley
'95/NAS D90 SW #59/500
Try taking a square and verify that they are parallel to one another. Things can move. I'm sure you've try some kind of schlickem?
doscazadores
Vic Stull
none
Never mind, got it rollin' again. Maybe just accumulated crud that made it difficult. Just forced it free and moved it back and forth a few times and it's pretty tame right now. Wife'll be able to move it herself whereas before I couldn't even do it.
------ Follow up post added January 24th, 2015 06:03 PM ------
And thanks, Mason. Didn't think about that, making sure it was squared up, but did shoot a little spray lube in there - for what it was worth.
Old January 24th, 2015, 09:29 PM
cascade90's Avatar
cascade90
Mason Worley
Glad to hear. You might not get her out of it now
Old January 24th, 2015, 09:56 PM
If the truck is properly used it should be clogged up with mud. If not it's Coke, french fries and goldfish crackers stuck in the tracks. Spray silicon is your best bet to keep them moving.
Old January 25th, 2015, 12:06 AM
Lithium grease or better yet wurth hs2000 is good to keep them free and rust free.
Old January 25th, 2015, 01:37 AM
dry lube like silicon best
Best lube for... head bolts ? JFD Defender Technical Discussions 20 April 8th, 2013 08:48 PM
lube this 97Ariesblu Misc. Chit-Chat 11 May 27th, 2011 02:54 PM
Parking Brake Cable Lube SPIKE Defender Technical Discussions 0 October 24th, 2009 12:43 AM
Lube Fittings Dfndr90 Defender Technical Discussions 4 October 14th, 2004 08:12 AM
Lube Suggestions TDI Guy Misc. Chit-Chat 7 January 19th, 2004 07:56 AM
