Lube Fittings - Defender Source
Old October 13th, 2004, 01:20 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Question Lube Fittings
Dont know if this has been covered, but cant find anything when searching the forum.
How do I know if the fittings on me D-90 need to be lubed, and how do I know if I have put enough lube in them? I do not want to blow and of the rubber boots off the fittings.
Sorry mike I tried to find some similar threads, but no dice.
Matt...
Old October 14th, 2004, 01:10 AM
what rubber boots are you talking about, O and mike is harmless
Old October 14th, 2004, 02:41 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
On the prop shafts just add grease until you see fresh grease start oozing out then wipe off excess. On the sliding part of the prop shaft I usualy add a couple of pumps with the grease gun. I do this maintenence every oil change and before and after I have gone wheeling. Don't worry about blowing seals out.
Old October 14th, 2004, 06:37 AM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Thats exactly the info I was loking for. Thanks Kevin!
Old October 14th, 2004, 08:12 AM
Matt, if you can't find what you are looking for by searching then there is no problem with a new thread. And Kevin is right on, but before I grease them I give them a good shake to see if any of the UJs are loose.
Parking Brake Cable Lube SPIKE Defender Technical Discussions 0 October 24th, 2009 12:43 AM
200 TDI Oil Cooler Line Fittings 49COE Defender Technical Discussions 1 October 13th, 2009 08:21 PM
Diesel Fuel Filter/Primer Michael Defender Technical Discussions 16 August 15th, 2006 12:45 PM
Zerk Fittings on Drive Shafts ronward Defender Technical Discussions 15 January 23rd, 2005 11:27 AM
Lube Suggestions TDI Guy Misc. Chit-Chat 7 January 19th, 2004 07:56 AM
