LT95 Issues - Defender Source
Old January 15th, 2011, 03:46 PM
rondo
Rondo B
Defender 100
LT95 Issues
My LT95 recently stuffed itself while going down the highway. Other than the fact that the thing screams like all 95's and Faireys, the only indication something is wrong with it is it won't stay in high range. It drives normal in low, but when shifted into high it clunks into and out of neutral loudly and forcefully (broke my shift knob).
Went into the transfer case this morning to rule out a quick repair with what replacement parts I have available. Some interesting gasket material on the transfer case and the overdrive. Seems to have held up great though.
All of the gears have a small bit of play to them at some point depending on whether its in high or low. Having never opened this kind of transmission before, I have no idea whats normal. Also beyond the copious amounts of metal shavings, no huge amount of visible damage and no sign of where that big chunk of metal came from.
Any experienced eyes out there that can help me out here?
ID:	34793   Click image for larger version
ID:	34795   Click image for larger version
ID:	34797   Click image for larger version
Old January 15th, 2011, 04:31 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Are the shavings magnetic? If not then they are probably from the layshaft shims. when they let go, you get a bunch of play, enough so that it can pop out of high.
Old January 15th, 2011, 04:33 PM
rondo
Rondo B
Defender 100
Some of the shavings are magnetic. A lot of them are brass.
Old January 15th, 2011, 04:41 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Sounds like the shims went. You'll need to check how much float there is. You can re-shim without removing the transmission (fiddly job) or if you're up to it find a tapper roller bearing kit ($$) and make it much stronger. Or replace it with a new or used unit. A few of us have a spare LT95 sitting in the garage.
Old January 15th, 2011, 07:45 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
I have a lt95 available...in good shape, was working well when removed...
Old January 15th, 2011, 07:52 PM
I never took one of those apart but what I believe is the low range (small) gear on the intermediate shaft looks like it might be discolored as if from heat. Or it could just be covered in oil. I would check that out. You could always just rig up a big rubber band and save for an LT85 setup.
Old January 15th, 2011, 08:07 PM
grnrvrs's Avatar
grnrvrs
Paul
88
If one were to swap gearboxes from an LT95, to something else, why an 85? the late spec R380s were stronger, right?
Old January 15th, 2011, 11:15 PM
rondo
Rondo B
Defender 100
Yeah, I'd probably detonate the LT85 behind the 6.5. The R380 is probably stronger than the 85, but the 95 is said to be stronger than both.
The gear is certainly discolored. Looks to be baked on oil from... overheating?. Otherwise it looks like it didn't sustain any damage. That is the low range gear though, so unsure why it would have gotten so hot.
Old January 15th, 2011, 11:20 PM
I always thought the LT85 was the strongest 5 speed
Old January 16th, 2011, 06:33 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I've got the overhaul manual for the LT95 here if you want a copy. Fling your email over.
Old January 16th, 2011, 10:20 AM
rondo
Rondo B
Defender 100
PM sent, thanks for the offer!
Old February 8th, 2011, 11:26 PM
rondo
Rondo B
Defender 100
So thanks to everyone that sent me manuals and words of encouragement. Took it apart a couple weeks ago and ordered up some repair parts from John Craddock. About 500 bucks later they arrived (yesterday) and I rebuilt the transmission this afternoon. Went pretty quick and was done in a few hours, to include having to fabricate two tools to get the intermediate shaft out (it was really welded in there from the melted bearings). Turns out the thrust bearings were gone, hence the bronze bits, and two of the three needle bearings were completely without their plastic bearing races. Why are they made of plastic? Pretty crazy... All new gears, bearings, washers, seals and shafts in the transfer case. Not bad!
Anywho, the gear box is back up and running!
Old February 9th, 2011, 11:57 AM
grnrvrs's Avatar
grnrvrs
Paul
88
Sounds like a good deal.
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Server issues chrisvonc Support & Suggestions 4 June 16th, 2005 01:17 PM
EMERGENCY-Xfer case issues Cyborg Defender Technical Discussions 7 July 18th, 2004 02:50 AM
Getting Help, Outstanding, & Known Issues chrisvonc Support & Suggestions 0 May 23rd, 2004 06:00 PM
Lt230 & Lt95 tbmcneill Defender Technical Discussions 4 February 21st, 2004 04:23 AM
