LT95 gearbox ratio discussion - Defender Source
Old February 4th, 2016, 11:07 AM
Tallergypsy
Ray Wood
1984 Australian Built 110 4BD1
I'm lucky to own a 1986 Australian built 110 fitted with the Isuzu 4bd motor and the LT95 gearbox. Over the last ten years I driven it extensively in Africa Europe and North America. It is the most reliable Land Rover I've ever owned.
On the 4000 Km drive back to Vancouver from the Arizona rally Last year I gave some thought to changing the ratios to give the truck better highway performance. I think it could cope with about 10 or 12 % lower overall ratio. An overdrive at 28% would be far too over geared to be useful which is the reason we don't make a Roamerdrive
There are no available lower transfer case gears available to swop as the existing ratio is already 1:1. It is not possible to cut some custom gears for the lower case as the diameter of the lower shaft is too big to accommodate a smaller diameter gear. You could replace both the front and rear diffs but that gets quite pricey and there is nothing out there quite right ratio wise
I'm thinking of cutting a myself a set of gears that would replace the upper two gears in the transfer case to bring the ration up by 12%. I don't this will effect the off road performance significantly as it such a low geared beast anyway. Anyone have any thoughts on this?
Ray
LT95 Gearbox, good working order. Bunky For Sale - Parts 0 May 7th, 2015 06:12 PM
LT 95 gearbox..do I have to remove gearbox from truck to replace reverse idler shaft? Ncmike Series Technical Discussions 3 April 13th, 2014 03:33 PM
Stereo Discussion bradleyt09 Misc. Chit-Chat 13 October 3rd, 2013 10:10 PM
Great day ends with long Geico discussion COphinest Misc. Chit-Chat 9 July 19th, 2012 06:39 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
