LT77S Transmission and Clutch slave leak - Defender Source
Old September 9th, 2013, 08:55 PM
Mpfish82's Avatar
Mpfish82
'94 AA Yellow D-90 #690
My clutch started leaking last month, refilled the master reservoir and have been good till last week. Clutch went to the floor again, checked the fluid and again, empty. So I have a leak.
I ordered a new slave cylinder thinking that was the issue. After spending more time under the truck this evening I am thinking the leak is from the tranny as well as the slave. Is this a typical issue with the LT77? How tough is it to drop the tranny and have all of the seals replaced? Is there anything I should have done while I have the tranny dropped? I am more than likely taking to a local shop because the closet Rover shop is little over an hour away, unless you guys think this is too complicated for a good mechanic that doesn't have Rover experience. Thoughts?
Old September 9th, 2013, 10:49 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
First Plan for repairs.
Originally Posted by Mpfish82 View Post
My clutch started leaking last month, refilled... checked the fluid and again, empty. So I have a leak.
You should always replace the clutch master and slave cylinder together. When you don't the one you didn't replace usually fails shortly after the initial replacement.
When the slave cylinder leaks, the fluid goes into the transmission belhousing and a portion of it will eventually leak through the wading hole.
Can't tell from your description if this is what's happening, but I would replace the clutch hydraulics, unless you are 100% positive that you have a transmission leak and what you see is NOT brake (clutch) fluid.
Hope this helps.
RDavisinVA
Old September 9th, 2013, 11:12 PM
Mpfish82's Avatar
Mpfish82
What else could it be if not a leak?? It is steadily losing fluid and I keep needing to fill the master. There doesn't appear to be any fluid between the master all the way down to the slave.
There is definitely fluid on the garage floor that is same color and consistency of the clutch fluid. When I took some time to really look it over today it seemed like a lot more than just from the slave. It appears to be all around the seal areas of the transmission and drops forming on the large bolts on the under side of tranny.
Old September 9th, 2013, 11:36 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Yes we know the fluid is leaking... that's why I recommended:
"You should always replace the clutch master and slave cylinder together. When you don't the one you didn't replace usually fails shortly after the initial replacement."
So it's a given you need to replace your clutch cylinders and a new hydraulic hose won't hurt as well.
"When the slave cylinder leaks, the fluid goes into the transmission belhousing and a portion of it will eventually leak through the wading hole."
So if you are sure you have 2 leaks, then you can by all means pull the transmission to fix it, but if you replace the clutch cylinders and hose and the leaks are gone, then you won't need to pull the LT77 (which is not trivial). Also it could be leaking from a plug, breather, or loose fitting which can be fixed in place.
What fluid is in your LT77? If its ATF and dyed red, it can easily be identified as something other than brake (clutch) fluid and if you then have no red drips, than your LT77 is not leaking.
Again, hope this helps. Good luck.
RDavisinVA
Old September 10th, 2013, 06:29 AM
Mpfish82's Avatar
Mpfish82
Thank you for the advise. I am going to go ahead and add the other pieces to my order and replace those at the same time.
Unfortunately the clutch fluid is just the standard and doesn't have a red dye. I will try to pick some up today with the dye and that way may be able to pin point the exact location of the leak. I agree last option should be wanting to drop the tranny and start rebuilding seals and gaskets.
Old September 10th, 2013, 07:36 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Please go back and read the last post again... Think I confused you.
In your first post, you mention the possibility of 2 different leaks:
One from the clutch hydraulics and one from the LT77 transmission.
So advised you to replace the clutch master and slave cylinders (which can be done without pulling the LT77 transmission out of the vehicle) and also replace the flexible clutch hose for good measure.
Was asking if you knew what fluid was in your LT77 transmission... that's what will be red,
I am not aware of any red brake fluid used in the clutch and always use Castrol LIMA dot 4 brake fluid.
After your cylinders are replaced and your clutch fluid leak fixed, then you can wipe everything down and look for transmission leaks from your LT77 which could be red fluid.
And finally, you'll need to buy the workshop manual and study it as it will provide better step by step guidance that you can get from replies like this.
RDavisinVA
Old September 10th, 2013, 08:55 AM
Mpfish82's Avatar
Mpfish82
Took some pics of the slave, tranny, transfer case, etc. hoping that seeing what I am looking at may help.
ID:	79386   Click image for larger version
ID:	79388   Click image for larger version
ID:	79390   Click image for larger version
Old September 11th, 2013, 01:48 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
If the clutch master is running dry it can only be from a leak in the master, slave, or clutch line. If you replaced the slave check pull the drivers side floor mat and see if its wet with fluid. If so, I'm 99% sure the leak is from the master.
Replacing the master can be a pain the first time around. Just remove the hood to make it easier. Whole job should take less than an hour.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
Transmission or Clutch prob?? kiefffff Defender Technical Discussions 4 June 29th, 2006 10:55 PM
'94 clutch and transmission question CDN38 Defender Technical Discussions 4 January 31st, 2006 01:32 PM
Lifting engine and transmission together?? cbass Defender Technical Discussions 5 November 7th, 2005 06:23 AM
Transmission clicking? oldscratchggf Defender Technical Discussions 1 June 14th, 2005 06:42 AM
