LT77S to R380 in 94? - Page 2 - Defender Source
Old December 20th, 2012, 02:35 PM
bjf's Avatar
bjf
barry f
94 ST #395
Funny enough my 110 had an r380 but terrible slop. Turns out the input gear was totally stripped. I put in one of the new cross drilled gears and it was all good.
Any details on this low mileage 94?
Old December 20th, 2012, 02:36 PM
A good LT77 feels and shifts fine. The R380 is a little smoother, but it is not a big difference.
Old December 20th, 2012, 04:15 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
It would be stupid to not buy a solid truck just because it has the LT77. Are you looking for reasons NOT to buy a truck?
My truck, #48 still has the LT77. Somehow it was never replaced by the original owner, probably because it works fine. If you are a patient driver, it shifts without issue. The same was true with the Porsche 915 gearbox. Patience is rewarded.
No matter how long you look, you're not going to find a Defender that shifts like your Honda Accord.
Old December 20th, 2012, 04:20 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Ditto for my #639 (Redline MTL). Guess I need to drive a truck w/ the R380 to see what all the fuss is about.
Old December 20th, 2012, 05:12 PM
maleger
Marc-Andre Leger
My canadian #18 NAS D90 (1994) has the LT77 and it is fine. Never had any significant problems at 179000Kms.
Old December 20th, 2012, 05:19 PM
jac04's Avatar
jac04
Jeff
Currently Roverless
Not at all. I'm simply trying to become an informed buyer.
Old December 20th, 2012, 05:42 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Just don't start being picky, apparently that is frowned upon. Good luck with your search.
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old December 20th, 2012, 05:53 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Not targeted at you....
---- Edit ------
That said, Matt, other than posting every truck for sale on the continent, a little Horsey search magic may do you some good:
Nearly the exact question about the R380
http://www.defendersource.com/forum/...ad.php?t=39053
I'm sure there's more, enjoy
http://www.defendersource.com/forum/search.php
Old December 21st, 2012, 10:52 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I still have an H code LT77 in my truck and love it. I have driven several several R380's and only one shifted nearly as smooth as my LT77 (currently 125K on it). I think it is worth noting that there are more desirable LT77's (such as the H and maybe G code) so take a look at the serial number stamped in the side of the transmission (will be on the RH side behind the bellhousing).
I also really like having reverse and 1st next to each other but I also must admit that I am partial to it because I grew up shifting a Ford toploader 4speed which was the same
Old December 21st, 2012, 10:57 AM
jac04's Avatar
jac04
Jeff
Currently Roverless
Ha! I hear ya!
Old December 21st, 2012, 11:01 AM
down_shift's Avatar
down_shift
Russell
Jeff, I didn't realize that our badges are 16 numbers apart. Thanks for the tip on the transmission codes. Will check mine and report back.
Old December 21st, 2012, 11:03 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
You have an LT77 or R380?
Old December 21st, 2012, 11:05 AM
down_shift's Avatar
down_shift
Russell
LT77 and it shifts fine. No issues.
Old December 21st, 2012, 11:16 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I recommend taking a picture of your serial number after you finish cleaning it off in case you ever need it again!
r380
WANTED: Clutch for '94 D90 with R380 jijalicious Wanted 4 December 21st, 2011 10:50 PM
When did the R380 start to show up in '94? MakoShark72 Defender Technical Discussions 8 June 4th, 2010 12:41 PM
3.9 engine, R380 transmission Shane@EVS For Sale - Parts 7 August 3rd, 2006 04:04 PM
r380 diesel/v8 question D90user Defender Technical Discussions 5 January 1st, 2006 07:15 PM
R380 source opinions D90user Defender Technical Discussions 12 December 8th, 2005 12:22 PM
