LT77S mainshaft wear how much is ok? - Defender Source
Old April 13th, 2014, 10:23 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I removed and inspected my input gear and mainshaft splines each are missing about 25% of the original splines. I have read on various uk forums that the guys have worn them down to almost nothing and still driving it. I plan to do a fair amount of traveling this summer and if I can limp it along to this winter I will otherwise Ill probably just order all the pieces from ashcroft and rebuild it now. I have pretty much already decided the right thing to do is rebuild it now but I dont want to end up spending all summer doing repairs again this year (last year was a new chassis and full suspension rebuild as well as a few other things). Ill also end up doing the lt230 at the same time.
Ryan
Ryan
84 110SW County LHD
07 L322 Vogue
Old April 14th, 2014, 12:13 AM
It won't sheer at that level. I would run it with a cross drilled input until the trans died.
Old April 14th, 2014, 08:29 AM
Sounds fine. Add the oiling disc for the time being.
What suffix box is behind the 200TDI?
Old April 14th, 2014, 08:31 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
H. I plan to just tear it down and do a rebuild.
Ryan
84 110SW County LHD
07 L322 Vogue
Old April 14th, 2014, 09:27 AM
There is no need really. Install an oiling disc or a cross drilled input gear and it will last forever. Unless there is some other problem, there is not reason to rebuild it.
R380 Transmission/Gearbox - Only needs a mainshaft bearing fitting overlandbirds For Sale - Parts 0 December 3rd, 2013 09:29 AM
socket 600300 needed for tbox mainshaft nut jack SF Series Technical Discussions 1 February 14th, 2013 12:06 AM
front tires wear much faster than rears? tommyd Defender Technical Discussions 19 May 4th, 2012 03:15 PM
V8 LT77s evilfij For Sale - Parts 1 October 11th, 2009 11:36 PM
Sagging Suspension: How Much is Too Much? aclarke Defender Technical Discussions 9 June 19th, 2007 04:41 PM
