LT77 Wading Plug - Defender Source
Old March 11th, 2013, 02:39 PM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
LT77 Wading Plug
I know where the plug hole is supposed to be located, but there just isnt a hole to be plugged. Did some of the ROW defenders with LT77s not have these holes? I am a bit confused
1987 ROW D-90 LT77 2.5td
Old March 11th, 2013, 02:47 PM
Not that I know of. Are you sure there is not a plug in it already? It is in the clutch cover, which is more technically part of the engine.
Old March 11th, 2013, 02:59 PM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
pardon my ignorance, but by Clutch cover, do you mean bell housing?
Old March 11th, 2013, 03:09 PM
No. The clutch housing is over the clutch and flywheel and bolted to the engine. The bellhousing is bolted to the gearbox. The clutch housing and bellhousing are bolted together and that is how you separate the engine and gearbox.
Old March 11th, 2013, 03:15 PM
OK, to avoid confusion, Land Rover calls it a "flywheel housing". On a 2.5TD, the plug is on the front bottom of this housing. See attached... ERC7295 is the plug.
Old March 11th, 2013, 03:43 PM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
Got it! I was under the impression it would be on the bottom, not on the side. What are the downsides of having it plugged constantly?
Old March 11th, 2013, 03:45 PM
If you develop an oil leak, the oil could get into the clutch.
Old March 13th, 2013, 01:01 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Weird- mines on the bottom
Wading plug and drain hole? T.U. Defender Technical Discussions 4 April 6th, 2010 03:48 PM
Lt77 TexasD-90 Defender Technical Discussions 4 November 8th, 2005 04:39 PM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
Serial Link Mating Plug? Ramsay Defender Technical Discussions 9 May 13th, 2004 11:27 PM
