LT77 Trans - Defender Source
Old August 10th, 2013, 10:32 PM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
LT77 Trans
Our 110 trans has been feeling a bit notchy lately and crunchy when cold while shifting up through 2nd and 3rd. I decided to replace the fluid with the Redline MTL since everything I've read about it has been very positive. After changing the fluid over I went on a quick drive and the shifting is definitely smoother...still a bit notchy, but not crunchy at all. Still when going into 3rd I get a bit of kickback, so what do you all think about that? Also the photos below shows a piece of metal which was on the magnetic drain plug...It had a good bit of the usual grime, but no other parts!! This is definitely a sliver, w all sides polished smooth except the longest side which seems like the area where it detached...any ideas?? The photos show the piece from 3 different sides. Thanks in advance!
ID:	77352   Click image for larger version
Old August 11th, 2013, 10:16 AM
looks like the tip of a gear tooth.
-Jeff
If it is steel, that seems likely, if it is aluminium, I would think part of the casting.
Old August 11th, 2013, 11:45 AM
And a very special bit of aluminum with magnetic properties!
Anyway, I wouldn't worry about it too much. Start saving those pennies for an eventual rebuild. In the meantime just keep driving it and see if anything else comes out.
Old August 11th, 2013, 01:38 PM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
It sticks to a magnet well and looks to be steel, so I bet the tooth tip is a good bet. We've put about 10k on it during the last year, and the trans still feels about the same, so hopefully it'll keep holding together for a while . It does have 115k on it though, so it's just a matter of time...
Thanks for the TIPS...ba da bing
Lt77 diesel trans with bad 2nd gear synchro the rover shop For Sale - Parts 13 May 6th, 2013 09:18 PM
SW doors/ LT77 trans/ 1.6 t/c tomaco1 For Sale - Parts 7 April 21st, 2009 02:49 PM
Rebuilding LT77 Trans... Stmpede Defender Technical Discussions 11 March 21st, 2007 08:24 AM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
